Pro's And Con's Of Using A Rear Disk
monty boi
PROs: good brake...
CONs: snap the rotor, bend the rotor, cost loads, i would'nt use one unless i got new frames free every time they snapped :P
adam don't even think about buying one, because' i'll snap it for you... :D
best pro: buckled wheels don't seem to much of a problem anymore.
worst con: your bound to snap it or bend i bad.. thats why most people don't use them in trials.. because the back wheel is nearly always lower than the front, and more prone to get bent..
Pro: Good brakeing
Con: Not many good disk hubs.
King?Profile?Echo?Monty?Bikegas?
Either FFW which people use, or Profile/King which people use with hs33's anyway.
Not very good on street aparently, no modulation, or too much or something :S I dunnoooooo'.
Mat
He's right. Only use discs with REAL disc mounted frames, otherwise you'll snap it.
I don't really like the feel of rear discs, it just feels a bit lifeless almost, like you can't really feel anything through it? Not to mention that with a HS33 if it starts to not work so well you can just throw some tar on or put a new grind on, and it's not really the same with discs.
I'd say the feel was the biggest "con" of it though.
Use the search, there are a few topics like this.
I think they have great stopping power, but the bad things are......they stop the spokes rather than the rim if you get me, there is slight modulation so it will slip and could be scary if you do a high drop and land steep.
But if you can have a shot of one and see what you think for you're self. Every one has very different opinions, just like front brake, some people like, disc some like magura and others like avid v brakes.
ok people :rtt: ! the same answers have been given about 10 times now.. we get it lol.. i'm not flaming but unless you have something constructive and new to say, don't bother crowding the thread!
Lol????
He asked for peoples opinions, pro's and con's
So people gave him theres?
Mat
Pros, good power, more selection than just the hs33...
Con, needs a the mounts and hub for it, I would prefer riding them on a stock or 24"er, because I think you'd have higher chances of hitting the disk on a mod then on a stock. :unsure:
Take in consideration wish way you tipicaly sidehop, also.
Great a topic where i can use what ive just found. This is clive leesons latest venture, the "2win disc"
IPB Image
IPB Image
IPB Image
IPB Image
i know showing this is a bit off topic, but dosnt it look lovely and proof to you that rear disc's probely can work really well, i just hope that you side hop to the right and bending it wont be much of a problem.
for a full spec on the 2win disc go here or check out ww.leesonbikes.co.uk
