mark145 Posted August 1, 2006 Report Share Posted August 1, 2006 Hi The main question i have is would any 19" rim fit on a Onza T-Vee bike. I would also like to know if anyone has done this succesfully. If this was to work would i need Maguras due to being able to adjust them more. Thanks Quote Link to comment Share on other sites More sharing options...
The lemonade man Posted August 1, 2006 Report Share Posted August 1, 2006 No, it wouldn't. Do a search, there's like 100 topics on this. You're brake would not fit on the rim unless you fancy welding some mounts on.Not even a magura. Quote Link to comment Share on other sites More sharing options...
Euro Braker Posted August 1, 2006 Report Share Posted August 1, 2006 You could make a disc mount for a 19" wheel or you could get a better frame Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted August 1, 2006 Report Share Posted August 1, 2006 everybody seems to forget that with a quick bit of hacksaw work and a file, you can cut the dropouts a tad deeper so the wheel goes further in soooorted Quote Link to comment Share on other sites More sharing options...
roby James124 Posted August 1, 2006 Report Share Posted August 1, 2006 everybody seems to forget that with a quick bit of hacksaw work and a file, you can cut the dropouts a tad deeper so the wheel goes further in soooorted Thats one good idea. Rob Quote Link to comment Share on other sites More sharing options...
Josh Greenan!!!!!!!!!! Posted August 1, 2006 Report Share Posted August 1, 2006 My mates accualy worked. He just slid the pad on the vee down enough. Jobs done. Quote Link to comment Share on other sites More sharing options...
basher Posted August 1, 2006 Report Share Posted August 1, 2006 everybody seems to forget that with a quick bit of hacksaw work and a file, you can cut the dropouts a tad deeper so the wheel goes further in soooorted or you could buy a 20 inch rim. and like some else said no you cant put a 19 inch rim on a t-vee. your best off not doing any of the bodging people may sugest and just use a 20inch rim it just makes things alot easier. Quote Link to comment Share on other sites More sharing options...
mark145 Posted August 1, 2006 Author Report Share Posted August 1, 2006 Thanks for the replies, the only reason i asked is that there isn't really a big range of wide 20" tires. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted August 1, 2006 Report Share Posted August 1, 2006 or you could buy a 20 inch rim. and like some else said no you cant put a 19 inch rim on a t-vee. your best off not doing any of the bodging people may sugest and just use a 20inch rim it just makes things alot easier.why not? it wont really hurt, and will allow a far better range of rear rims and tyres-it can be/has been donealso its not bodging, its modification, subtle difference also, per chance did you get the t vee frame off ebay for a tenner? if so that was mine Quote Link to comment Share on other sites More sharing options...
mark145 Posted August 1, 2006 Author Report Share Posted August 1, 2006 I dont really fancy modding or bodging and no paul i didn't buy it off ebay. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted August 1, 2006 Report Share Posted August 1, 2006 I dont really fancy modding or bodging and no paul i didn't buy it off ebay.ahh well, enjoy having a crap selection of stuff then i guess a front creepy could be ok for a begginer? just run it with a bit more pressure or be a man and do the easiest and best fix Quote Link to comment Share on other sites More sharing options...
Joel G Posted August 1, 2006 Report Share Posted August 1, 2006 Thanks for the replies, the only reason i asked is that there isn't really a big range of wide 20" tires.thats becasue a t-vee is the cheepest trials bike u can by brand new der ment to be less hasel than the other mods but also more basic Quote Link to comment Share on other sites More sharing options...
ashby-trials Posted August 2, 2006 Report Share Posted August 2, 2006 My friend did it, it worked well all he had to do was just adjust the maguras and the job was a good one. Quote Link to comment Share on other sites More sharing options...
sunn_bmixx Posted August 2, 2006 Report Share Posted August 2, 2006 search through the topics as i remember this guy who had a really nice monty 26" but had a smaller wheel i think. Anyway the point is on there was a guy who can build the convertors that bolt into your old mounts to creat new mounts. I cant rerember the name of the topic but i will have a look for you to see if i can find it.hope this helpsIan B Quote Link to comment Share on other sites More sharing options...
