rambo Posted August 1, 2006 Report Share Posted August 1, 2006 (edited) hello i have a small grind left on my rim but i want to go to tar on my rim i use tar already but it is getting lose so fast and then i mean within 5 hours off riding, i place it in strokes on my rim. my question what can i do to let it stay longer on my rim? Edited August 1, 2006 by rambo Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted August 1, 2006 Report Share Posted August 1, 2006 hello,I use a smidge of tar on a heavy ground rim and it gets worn off in about 2-3 hours, its best just to keep applying it, you cant really control how fast it gets worn off. just keep applying Tim. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2006 Report Share Posted August 1, 2006 yep, better to put on too little than too much.It's one of those high mainenance things... Quote Link to comment Share on other sites More sharing options...
roby James124 Posted August 1, 2006 Report Share Posted August 1, 2006 Hi Little but Lots Lots but little Let me now put this into english for you it is a lot better to put tar on your rims every hour and put a little bit on than, putting heaps of the stuff on but the only doing a few times a week. There are several reasons for this but the main one is if you put alot of tar on your rims the brake pads will stay stuck to your rims and not release the brakes. Hope this helps Rob Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted August 1, 2006 Report Share Posted August 1, 2006 (edited) Hi Little but Lots Lots but little Let me now put this into english for you it is a lot better to put tar on your rims every hour and put a little bit on than, putting heaps of the stuff on but the only doing a few times a week. There are several reasons for this but the main one is if you put alot of tar on your rims the brake pads will stay stuck to your rims and not release the brakes. Hope this helps Robthat makes no f**kin sense what so ever.if your running a grind and still need tar, maybe you should change you pads. Edited August 1, 2006 by alext Quote Link to comment Share on other sites More sharing options...
mat hudson Posted August 1, 2006 Report Share Posted August 1, 2006 no, maybe you just want a better brake. but you're "one of those" people. Quote Link to comment Share on other sites More sharing options...
jacks Posted August 1, 2006 Report Share Posted August 1, 2006 that makes no f**kin sense what so ever.if your running a grind and still need tar, maybe you should change you pads.nowhen the grind is running out you need to improve braking without renewing grind Quote Link to comment Share on other sites More sharing options...
