Snail Cams Or Chain Tugs
Egg Fried Rice
smooth steel snailcams are definitely easier to set up than chaintugs - it's a lot easier to be sure everything's butted up against everything else than with chaintugs -you also don't have to bugger about with 11mm spanners.
I dunno about the notched ones - i can imagine they're complete bastards if you're unlucky enough to have exactly the wrong length stays
chain tugs... always have used them, always will.
they are so much easier because (if you have a bit of slack on your chain) if your wheel has moved or is rubbing on a pad you can just tighten one side and stop the rubbing and tighten the chain at the same time.
steve.
