eskimo Posted July 30, 2006 Report Share Posted July 30, 2006 Simple question and a obvious answer but just to double check.Will a Eno fit on a rear mod hub? I wouldn't have thought it would but has anyone done it?Being mods use 12 and a eno is 18 tooth then the thread is very different. But maybe some one has pulled it off? Quote Link to comment Share on other sites More sharing options...
poopipe Posted July 30, 2006 Report Share Posted July 30, 2006 the threads are the same - your problem is having to run a 27 tooth cog up front to get the gearing right. Quote Link to comment Share on other sites More sharing options...
eskimo Posted July 30, 2006 Author Report Share Posted July 30, 2006 Oh yeah. I fogot about the gearing.It's still early. Maybe ill give the idea a miss. Cheers though. Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted July 30, 2006 Report Share Posted July 30, 2006 Not unless you get a t-bird or bmx hub and run a big cog up front. Quote Link to comment Share on other sites More sharing options...
