monty boi Posted July 28, 2006 Report Share Posted July 28, 2006 (edited) Monty 219 alp(06)From cleanbikes.co.uk£350My Review- The monty 219 is a very light and flickable bike, the bike has inproved me alot e.g gapping and launching.The parts are not too cracking but will last about a year or two.The only problem is the bike comes with v-brakes and are rubbish or you could upgrade to the 219 magura if you have the money).I have ridden the bike since christmas and i have not had hardly any trouble with it(exept the brakes) overall i would rate this bike 7 out of 10.One its cheap and two its light and the frame is fairly strong too.And feels pretty good on the rear end.Just thought i'd post a review incase anyone is thinking of purchasing onecheers guys.Heres the spec.Colours - Red/Black/White or Scotchbrite (silver) Frame - Monty 7005 T6 Tig Plus Shock absorbing frame, Concave design. Fork - Monty Hi-Ten Tig plus welding. Blades diameter 31.8mm. 100mm wide Headset - 1-1/8" ID 28.6mm Cartridge type Rubber seal Stem - Monty 6061-T6; Length 150mm; Rise 25°; Bar bore 28.6mm; Finish black Handlebar - Monty Hi-Ten; Length 680mm; OD 28.6mm; Rise 10° back and 11° upwards Brakes - Forged alloy V-brakes; reach adjustment; dual spring; black finish Bottom Bracket - Square type; Sealed bearings; Chrome Moly axle; Length 127mm; 1.37 x 24T Cranks - Monty 6061 T6; Square type; Length 152mm; 24T Chainwheel Freewheel - 18T; W 1/2"x1/8"; CP finish Bashplate - Monty Aluminium; Saw shaped Rims - Monty Aluminium; Front 20" x 36 hole; Rear 19" x 36 hole Tyres - Monty special BikeTrial; Front 20" x 2.0"; Rear 20" x 2.7" Adam Edited July 28, 2006 by monty boi Quote Link to comment Share on other sites More sharing options...
