Brake Pad Problems
craigjames
right ok, i'm running heatsink blues, on a maggy with evo adapters on a d521 rim. clean everything up rim, pads etc. pistons lubed and movin fine. but after about 2 minuts of the brake bein set up pretty damn well and screamin like a banshee it goes all quiet and the grab and the bite go. i take the pads out and there covered in blacl/silver dust. surely this cant be rim dust as i cleaned it all down and its only literally 2 minutes after that it stops workin.
the brake works amazin whilst its screeching but as soon as it stops the brakes a great big pile of poo
help!! is there anything that im probably doing wrong, should the pads be covered in this dust after such a short period?
cheers
craig
is it black on the rim too? i used to get it from riding wet natty.
nope completely clean rim before and after, that whats confusing me?!!!
i'm a fair weather rider, mainly because i can't get the damn brake to work for more than 5 minutes!
Edited by curly_freak
i used one of my dads ge greasers which he said left no residue.
maybe i will have to put i grind on it then, hmm not too confident about it though, have to practice on a old wheel first
just noticed that master cylinder istn coming out properly, its lubed and cleaned, its omces out several times and retracts as normal and then just stays out, dont think this would help but i think the main problem is the pads...?
Nah, that will be the TPA most likly.
Turn the TPA right off, and then take brake off the bike.
Get pads off of the maggy, put angle grinder facing upwards on the floor, and just "touch" the angle grinder with the surface of the pad. do this intill the whole surface of the pad is shiny.
Now get your rim, and put a nice light grind on it (Y)
See what happens to your brake then (Y)
If you have never had/used a grind, i can GUARANTEE you, it will be AMAZING.
Light grind and clean pads is the way to go for best performance...
The only way you'll get a good brake for any amount of time with a totally smooth rim is to clean it all the time unfortunately - the pads pick up bits of rim (that's the grey stuff on your pads) quite easily.
I dont agree the problem is your pads , some heat sinks are defective and have a horrible sticky glue inside wich appears to be black it makes your brake stick and u lose power the best way to get rid of this is by using a softer pad i would say use a spanish fly pad and tar or some monty pads and tar. Last resort but a awsome brake is to put a light grind on sand till almost smooth and use zoo pads its the best brake ever i swear to god good luck mate (Y).
Hi,
I hope you find a way to eliminate the black gunk that's reducing the grip of your pads. I never did myself back in the days before Heatsink Pads. The continual need to clean the smooth rims was eliminated once I started grinding my rims.
Replying to your message Mark, I've got to the bottom of this problem now. The way I was degreasing the earlier pads for glueing (including the free extra slim pads I sent you back in the day) meant some were exposed to the degreaser for a unnecessary long period and that weakened them - it's powerful stuff!
In the very rare instances that you have defective pads, my customer care is the same as always; simply get in touch via email and I'll replace the pads. (Y) I hope that this gives you peace of mind!
Steve
I dunno, I just found my Heatsink blues to be pretty turd no matter what I did. That was for the 3 1/2 hours I got out of them before they wore down 3mm out of the 5mm I had, anyway.
cheers for you help guys think i mite have to give a grind ago, as im sick of cleaning the rim and then rubbin the pads clean with wet and dry all the time. mite get some heatsink reds and switch the blues to the front.
bit scared on the grinding front its a good job ive got lots of old wheels from my downhilling days.
cheers very much
craig
