ChrisP Posted July 27, 2006 Report Share Posted July 27, 2006 I was out yesterday for a few hours and was primarily practicing my trackstand. I managed to improve it and can balance for upto 7 seconds if i'm lucky. I also feel i'm not doing it properly because i have to move forwards more than a few inches at times and im really jerky with the movements. So i think i've found out where i'm going wrong but i would really appreciate some pointers from you guys: My chocolate foot's my left one so i turn the handle bars to the right but i turn the wheel almost 80-90'(degrees) and then i fall sidewise. When this happens what should i do? Quote Link to comment Share on other sites More sharing options...
Saracen Kid Posted July 27, 2006 Report Share Posted July 27, 2006 buy the tricks and stunts dvd from chilli video for £7.99 it will tellyou andteach you loads of others stuff likr backhop and stuff Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted July 27, 2006 Report Share Posted July 27, 2006 The wya i practisited when the weather was nasty wa sin my room in fornt of the tvSat on the bike and just practising that way. Then started using my feet on the tyres and stuff. Now i'm pretty good Quote Link to comment Share on other sites More sharing options...
Barbra Posted July 27, 2006 Report Share Posted July 27, 2006 put your wheel up against a kerb (thats how the cool kids spell it ) when your first starting off, once you've got that dialled try doing it on a slight uphill. Quote Link to comment Share on other sites More sharing options...
yoyoyo Posted July 27, 2006 Report Share Posted July 27, 2006 If you fall to one side,start to point the wheel that way. So if you going to the left, bring the wheel round to the left. Do it little by little, as big movements will ruin your balance. Just go until you are balanced.Also look 5-6 feet ahead, not sure how but it helps loads. Looking down at your wheel doesn't help at all.But keep at it and eventually you'll crack it. Quote Link to comment Share on other sites More sharing options...
imhereithink Posted July 27, 2006 Report Share Posted July 27, 2006 All you can really do is keep practicing, theres nothing wrong with moving a couple of inches to start with, what may help is try staying nice and loose and keep everything nice and smooth (harder than it sounds i know) it will come with time. What i like doing is trackstanding on a thin wall a couple of foot off the ground, that way you have to minimise your movement, otherwise you fall off Just practice and stick with it, and you'll be doin it in no time Quote Link to comment Share on other sites More sharing options...
ChrisP Posted July 27, 2006 Author Report Share Posted July 27, 2006 Thanks for the quick replys guys ill definatly try your tips out when im practicing later on. Once i've mastered, within reason, the trackstand what should i attempt next. Quote Link to comment Share on other sites More sharing options...
yoyoyo Posted July 27, 2006 Report Share Posted July 27, 2006 Can you bunnyhop yet?If you can, next i would start to try feeling comfortable on the back wheel. So probably back hops(hopping on the spot on your back wheel)If you need any extra help, try here. Quote Link to comment Share on other sites More sharing options...
Chris_P_Bacon Posted July 27, 2006 Report Share Posted July 27, 2006 Lean your body weight over the front of the bars. When you turn the front wheel rotate your upper body with it slightly and keep your head up. Like someone said buy tricks & stunts, Hans Rey will show you the way Quote Link to comment Share on other sites More sharing options...
