planet x alan Posted July 26, 2006 Report Share Posted July 26, 2006 hey guys, i need to remove an acs claw off my revolver to get to the spoke flanges to replace a couple of spokes. i have tried using a hammer and chizzle (sp?) and i have had no luck budging it. any other suggestions? thanks very much in advancealan Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 26, 2006 Report Share Posted July 26, 2006 You'll almost certainly need the tool. Without it, it's mad hard trying to get freewheels off. Ask around and see if anyone has one, if you don't. Either way, just try and use a long bolt to bolt the tool to the hub, then either mount the tool in a vice using the spanner flats on it or try and use a spanner on it, but either way - give it some beans.Main tip would be to get the tool ASAP and try and use that. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted July 26, 2006 Report Share Posted July 26, 2006 (edited) freewheel remover bolted to the hub. works like a charm. alternative meathod (i did this after delacing my wheel (non drive side) and forgetting about the driveside) remove lockring (smash with hammer and punch ) take everything off the freewheel. now you can lace your wheel up. whenm its done, clamp it in the vice, turn wheel. Edited July 26, 2006 by mat hudson Quote Link to comment Share on other sites More sharing options...
Monkey Posted July 26, 2006 Report Share Posted July 26, 2006 if he can do that, he just needs to put his freewheel back together afterwards...so, in addition, don't throw the parts away and prepare for some really fiddly work with pawls and bearings. Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 26, 2006 Report Share Posted July 26, 2006 You've got to be careful where you clamp it if you want to use it again; the vice tends to rape the freewheel body unless you make sure you clamp it on a strong bit. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted July 26, 2006 Report Share Posted July 26, 2006 uprade to a tensile at the same time Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted July 26, 2006 Report Share Posted July 26, 2006 uprade to a tensile at the same time Werd.Just take everything off the freewheel, so its just the freewheel body, then get some stilsons on the flat edges, with an extension bar on the end, then turn the freewheel off You will be supprised Quote Link to comment Share on other sites More sharing options...
planet x alan Posted July 26, 2006 Author Report Share Posted July 26, 2006 i have got my hands on a tool and i have attached it on and it still isnt budging Quote Link to comment Share on other sites More sharing options...
ogre Posted July 26, 2006 Report Share Posted July 26, 2006 There an absolute b*****d to get off with a tool, keep your tyre on (put it back on if you ook it off) pump it up to make the wheel bigger (mover leverage) and litterally bear hug the wheel and gurn better than TRA (grunting helps too), but you might need someone else to help you. Quote Link to comment Share on other sites More sharing options...
planet x alan Posted July 26, 2006 Author Report Share Posted July 26, 2006 grunting helps toohaha i will try that one. its so damn annoying Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 26, 2006 Report Share Posted July 26, 2006 You are turning it the right way, yeah? Quote Link to comment Share on other sites More sharing options...
Barbra Posted July 26, 2006 Report Share Posted July 26, 2006 Hammer and chizzle anti clockwise. Gorgeous job done. Quote Link to comment Share on other sites More sharing options...
Walleee Posted July 26, 2006 Report Share Posted July 26, 2006 Angle grinder Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted July 27, 2006 Report Share Posted July 27, 2006 Bolted on tool, with an EXTRA long extension bar Quote Link to comment Share on other sites More sharing options...
JT! Posted July 28, 2006 Report Share Posted July 28, 2006 Bolted on toolThat's a must. Quote Link to comment Share on other sites More sharing options...
