Opposite Driver Profiles.
Mr_Pitbull
If by "opposite driver" you mean left hand drive, then you can run Profiles LHD I'm pretty sure. Either way - cranks? Or just buy a Coalition cog guard and run that on the drive-side?
Good i have the link to this cog Guard Mark :-. and will it take the force of 13 stone smashing down on a failed sidehop.
Not sure, possibly is though, on my Python theres a little sidehop plate which is designed for when you miss a sidehop and you slam straight down on it. That sits pretty much next to my chain. I've f**ked up a brand new Profile in a matter of weeks. i will take Pictures of the Lock Ring. Its destroyed pretty much.
Edited by Mr_Pitbull
If you mean on the right hand side, I thought that little bit was just so when you went to bash, because the chain's going to get pushed up towards the frame it stopped on that block first instead of snapping/stretching/damaging your chain by pushing it right up to the yoke?
Biff, can you remeber that weird black plate Corish nicked off his grandad for his 05 red Monty to stop him breaking his profile?
All you need is some Tough flat plate steel. It will weigh quite abit due to the durability and the properties of the metal its self, but its well worth it, and wont be too noticable, be like fitting a heavy'er chain.
Im not at college till september, so if you wish making a tempary one for now, and soon as i get back i'le make you a pro fancy one :rolleyes: Will be the dogs bollox and amd correctly due to bending degrees and shapes blah blah.
Upta you mate =]
Scotty
P.S. Can somebody tell me where the hell the spell checker has gone :huh:
or you could get tensiles and put the replaceable screw-in pedal thread insert things in the opposite side crankarms somehow? then the threads would be the right way?
i'm not sure how they work
Nah, the inserts themselves wouldn't go in right, I don't think. They're threaded so they go the same way as the pedals when you tighten them, so I don't think it'd work too well...
Or just learn to sidehop the other way biff u homo :huh:
no al go shit.
Upta you mate =]
Scotty
Craig chucked it, i gave him some steel aswell to make me one, he hasn't got round to doing it yet. The only thing stopping me from completely destroying my profile is my KHE Chain, f**k me there amazing.
Amazing apart from the fact the rollers crack like f**k, they develop stiff links and they almost seize up if you don't ride your bike every day? :P Oh, and they rust incredibly easily, so it's not great if you ride in the wet or ride natural anywhere near a water source...
Tunni can sidehop mad high to his good foot side, so maybe follow his example? ;)
I did Sidehop to good foot side, then i changed :P. im kinda happy with the hight i can go now, im not willing to change it for a seazing Hub :P.
Not to mention the fact the cog would unscrew fairly quickly? :-
