Twin Chain Setup
how were you thinking about tensioning? did you have to splay your mech/tensioner cage and put another jokey wheel in? its a good idea, i was having a think about somthing like it, you'd have to be well unlucky to snap a chain with that setup.
I was thinking about it before but then i thought it was a waste of money although all i'd need is a new right crank and a new chain because i have a try-all hub and they have space for 2 fixed sprokets so i'd take a sproked off one off my old wheels. myte try it wen i start work and can afford to but at moment i can't.
sorry for boring you.
matt rushton
i dont see much point in having 2 chains running if you get a beefy enough chain you should be ok, but if you dont mind the weight then fine good idea (Y). ages ago i was thinking about running 2 maguras on the back as in mbuk a while ago but the added weight jus doesnt help.
Good idea hope it works well for you.
Matt Hall aka Big Matt
Was on his 5th Giant frame too
Worked at Bike wrokshop, The Rocket and Mud Dock.
He did it at Mudddock and Doddy saw it oneday when he came up...hensehn the feature in MBUK
Big Matt now works for Apple in some Mac shop (no the anorack style)
He had 2 working gears out of it all. The shop did offer it to be fi9tted for you as well but would cost £100
