Hayes Cable Disc Brakes
Saracen Kid
Is it this one,if so did you get a fitment manual for it ? if not i can send you a manuel that i have from when i bought mine last year if wanted, add me to msn : adzwatzon@hotmail.com or drop me an email.
yep those ones and to the post above i need a disc ready hub but the caliper rubs on the spokes :angry:
Edited by t-pro kid
i can't fit my newish hayes mx2 cable disc brakes but know how to fit them!!!! help me!!!
no shit sherlok use your head just a disk brake what you taling about
attatching the rotar
fixing the rotar so it dont come loose
using the right adapter
attatching the caliper to the fork
the best cable lever to use
why the f**k you chose a hayes disk brake
t-pro kid, if you just look at one persons post who has asked you about 4 things which might be the problem and answer all his questions properly, then you will find its much easier for someone to actually help you.
Have you put the rotor on the hub?
Have you got a good wheel build? Is it true?
Have you put the caliper on the right way?
Are you gay?
Yes?
Good.
Hayes cable disks are wank, why on earth do you want them instead of maguras :huh:
I'm affraid i have to disagree with you there my cable hayes is immense and has been eversince i bought it. thats even with a 160mm rotor on a stock, can't wait to get it on my mod it will be immense. The only trouble i had with it was when my pads glazed over all i had to do was sand them down a bit and it was back to its greatness again, i used to run one on the back of my ta 26 that was great aswell held well worked in all conditions. (Y) Therefore by my experiance of this brake it's great for the money.
Edited by watto
