How Do I Bleed Hs33
dbtrialer
Undo the bleed bolt on the cylinder (5mm allen key). Fill up your syringe and pipe, and screw that in the hole.
Then undo the small bleed bolt in the lever (3mm allen key?) Then pump the syringe until there is only water oil coming out the lever.
Keep pumping the syringe slowly, and put the lever's bleed bolt back in.
Then undo the pipe in the cylinder, and put a drop of water in the hole, then put the bleed bolt back on. (Y)
take your brake of the bike, take all the necessary tools and make a bathtub half full. Now you keep the whole brake under water and then simply bleed it. When the brake is under the water, try to pull the lever a few times to get the remaining air out of the hose.
btw you have to take water instead of mineral oil, of course ;)
