dbtrialer Posted July 18, 2006 Report Share Posted July 18, 2006 What pads are the best for wet and dry on a smooth rim. Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted July 18, 2006 Report Share Posted July 18, 2006 use the search!!! ... i would probs suggest zoo's but i doubt any pads will work awesome in wet Quote Link to comment Share on other sites More sharing options...
Dan-Gadd Posted July 18, 2006 Report Share Posted July 18, 2006 I have not used them myself but i would think the zoo pads would be good for a smooth rim as they are a soft compound. I dont know how they would peform in the wet but all pads will be worse in the wet especially if you dont have a grind. Also tartybikes reccomend them for use with a smooth rim. I use the standard kool stops myself but the only reason they work is because i have massive amounts of tar on my rims i only ride in the dry but i do remember once in the wet they were completely useless Hope this helps Dan Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted July 19, 2006 Report Share Posted July 19, 2006 Go use the bloody SERACH buttonSame time go to google and ask your self why didn;t you look about 1st of all Quote Link to comment Share on other sites More sharing options...
matt! Posted July 19, 2006 Report Share Posted July 19, 2006 grenn zoo or plazmatic crmz in my opinion or try black pads if you are brave Quote Link to comment Share on other sites More sharing options...
Alun Goch Posted July 19, 2006 Report Share Posted July 19, 2006 grenn zoo or plazmatic crmz in my opinion or try black pads if you are braveNOOOOOOO!! DO NOT USE PLAZMATIC CRMS IN THE WET OR YOU WILL DIE!Alun Quote Link to comment Share on other sites More sharing options...
juanpe Posted July 19, 2006 Report Share Posted July 19, 2006 i think that coust and zoo ....there is a koxx (blue) i believe that go good on water.. keep it up ! juanpe. Quote Link to comment Share on other sites More sharing options...
lardo_69 Posted July 19, 2006 Report Share Posted July 19, 2006 i remember using some megamo pads years ago when i was on the hs33. they worked really well in the wet a. i remember them being see through in complextion. they didt last long though so just try using them in wet weather if you find a set. Quote Link to comment Share on other sites More sharing options...
sam jordan Posted July 19, 2006 Report Share Posted July 19, 2006 I dont really know what pads would be the best but i recomend that you grind your rim. I only have v- brakes on my bike, as i am saving up for some hs33, but my brakes work really well. also try using tar on your rims if you haven't already. it works really well if you dont go over the top. hope you sort out you problem. sam Quote Link to comment Share on other sites More sharing options...
BIG L Posted July 19, 2006 Report Share Posted July 19, 2006 also try using tar on your rims if you haven't already. it works really well if you dont go over the top.Tar does not work in the wet. Anyway magura green frog pads work well in both dry and wet because of what they are made from or how they are made. Also koxx blues work well in both dry and wet! Quote Link to comment Share on other sites More sharing options...
