Small Gear, Smaller Run-up
Ra964
i used 19-17 ratio and went down to 19-18 i noticed that the runup distance slightly decreased, and I am now able to pedal up in places where it was imposible......
The run up is obviously going to be shortend as your running a lower gear :ermm: .
"I pumped my tyre up harder then i noticed i could roll faster" :blink:
don`t know, it seams to me that it`s 100% ok :D, I can go bigger than with larger ratios, I just use my body alot:D, and i guess that when i go for 18 - 15 (try-all fw or eno) after i get used to it it will be alot easyer:D,
and yeah i now it`s obvious, but i can go with the smallest runup distance you know:)), it`s fun when you can pedal up where other riders sidehop or pedal kick :-
