Tryall Cranks +ffw
Luzac
Looking into a pair of Tryall FFW since my old cranks died, how do they hold up? (square taper version)
should i get a fixed cog and keep the ENO on the rear or should i go FFW and put the fixed cog on the rear?
pros and cons of FFW with singlespeed?
pro : it's cool when you look down at the freewheel when you're coasting and its spinning around , smaller cogs
cons : trouser damage, less at the pedal EPs
beyond that, unless you're going to pay attention to things like chain slack making engagements happen later there's buggerall difference
