Danny Swindlehurst Posted July 17, 2006 Report Share Posted July 17, 2006 for all you mod gu riders out there and people who have had gus or no what pads are good help me please.hi people i'm having problems with my gu back brake.I've tryed different pads and different grinds but no of them work to well so... i wanted you guys to help me find some decent pads which will work in a 20" gu and what grind to run them on.At the moment I've got koxx greens on a light grind but i want some thing better cause its not the best of brakes,I've try diffent pads such as :plaz.koxx greens,magic pads,koxx blues.i'm wanting to try the zoos and the short cousts,I've got a brand new onza hog rim sitting in my room gathering dust and i'm waiting till i get some decent pads what work and then ill put it on so i can start from fresh!So please can you help or give me some advice to what pads to get on what grind and if so what grinding tecnique could use witch would make it better, i most appreciate the help given.cheers danny Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted July 17, 2006 Report Share Posted July 17, 2006 this might be stupid but have you tried a booster? Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted July 17, 2006 Report Share Posted July 17, 2006 Ive been using standard Heastink blues on a Ronnie rim for a while, they worked amazing in the dry with a fresh grind, they've started to lose power abit now but still work pretty good Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted July 17, 2006 Author Report Share Posted July 17, 2006 this might be stupid but have you tried a booster? you only need a booster if the frame flexes! Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted July 17, 2006 Report Share Posted July 17, 2006 you only need a booster if the frame flexes! Then why do people run them on zoo pythons ? Dan. Quote Link to comment Share on other sites More sharing options...
Robwalker Posted July 17, 2006 Report Share Posted July 17, 2006 More 'solid' feel to the brake system. And looks cool... Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted July 17, 2006 Report Share Posted July 17, 2006 Plazas on a medium grind=sex. As long as you set the brakes up properly. I also strongly advise the use of a space bar Quote Link to comment Share on other sites More sharing options...
Deonn h Posted July 17, 2006 Report Share Posted July 17, 2006 Then why do people run them on zoo pythons ? Dan.Cos the frames flex.When i press my brake you can see the mounts moving out at least 4 mm.I`ve got an 05 though , think they stiffend them up abit on the 06 but still .... Quote Link to comment Share on other sites More sharing options...
T-BAD Posted July 17, 2006 Report Share Posted July 17, 2006 well dan, since you ride comps... zoo pads in the wet are a no go. as you'v said you want some coustpads, i'd say buy the coust-sinks in the metal backings, get the lite green ones because there the dogs danglies These Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted July 17, 2006 Report Share Posted July 17, 2006 well dan, since you ride comps... zoo pads in the wet are a no go. as you'v said you want some coustpads, i'd say buy the coust-sinks in the metal backings, get the lite green ones because there the dogs danglies TheseThem metal backings rip the little nipple's of your pods, do not buy.Dan. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted July 17, 2006 Report Share Posted July 17, 2006 Sorry i'm probs being thickle here but what is the exact problem?No biteSlippingSpongeynessWhat exaclty?Have you tried the follwoing-Bleeidng your brakeChange of grinding disc, say use a metal cutting, my brakes worked tons better with thisCheck you 4 bolt moutns are not work where the bolt head sits. I had to bodge mine by using 4 spacer off an old chainThe threads in the frame for the bolts are not worn casuing the bolt not to be fully tigtened or fail when under loadOne very comen one is the black plastic C ring that goes around the slave. I seen a few without these and some even use the ring pull of milk cartens!! Don;t askJust some ideas there.Alext had issues with all his brakes but i got em working every time so any problems let me know, help where i can mate Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted July 17, 2006 Report Share Posted July 17, 2006 well dan, since you ride comps... zoo pads in the wet are a no go. as you'v said you want some coustpads, i'd say buy the coust-sinks in the metal backings, get the lite green ones because there the dogs danglies TheseThey aint all that good... yeah they have amazing lock, but they tend to slip when backwheeling a wall...Dan, get some nice bloox reds Im having troubles with the greens myself!They were amazing the first day i get em, then i got a f**king puncture and then had to take wheel out to fix it, put it back on and the brake was shit, has been since that day i hate f**king punctures!!!!! Quote Link to comment Share on other sites More sharing options...
nigel@hull_trials Posted July 17, 2006 Report Share Posted July 17, 2006 (edited) my mate craig has got a gu mod and he runs a echo booster kool stops and a harsh grind works ace ive got a 05 python with a czar booster zoo pads and a try all rim with a non grind its mint (Y)no slips even in the rain Edited July 17, 2006 by nigel@hull_trials Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted July 17, 2006 Author Report Share Posted July 17, 2006 (edited) Sorry i'm probs being thickle here but what is the exact problem?No biteSlippingSpongeynessWhat exaclty?Have you tried the follwoing-Bleeidng your brakeChange of grinding disc, say use a metal cutting, my brakes worked tons better with thisCheck you 4 bolt moutns are not work where the bolt head sits. I had to bodge mine by using 4 spacer off an old chainThe threads in the frame for the bolts are not worn casuing the bolt not to be fully tigtened or fail when under loadOne very comen one is the black plastic C ring that goes around the slave. I seen a few without these and some even use the ring pull of milk cartens!! Don;t askJust some ideas there.Alext had issues with all his brakes but i got em working every time so any problems let me know, help where i can matei've tryed all of them! nothing wrong with the brake it self i don't no why is crap?my zona back brake was bloody awsome and i wanted my gu to be like that as well! i had a medium grind on plaz it was a sexy beast of a brake B)its more of the slipping whats happening and its a bit spongey but i dont no if thats from the stain less magura hoses i have! or somthing else Edited July 17, 2006 by Danny Swindlehurst Quote Link to comment Share on other sites More sharing options...
nigel@hull_trials Posted July 17, 2006 Report Share Posted July 17, 2006 (edited) get a booster Edited July 17, 2006 by nigel@hull_trials Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted July 17, 2006 Report Share Posted July 17, 2006 Is that hose the Hope or magura kit? Magura one leaks as does the Unxe one and the Hope should be mental.What rim by the way as you haven't said along with grinding disc?Light grind doesn;t help on the rear!!Where are you in the uk....i'm really willing to blast this problem away and give you what you want Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted July 18, 2006 Author Report Share Posted July 18, 2006 i live in the north west in kendal,and by the way its the hope kit mot the magura stuff, i use an onza hog rim and a cutting or griding disc Quote Link to comment Share on other sites More sharing options...
Dan-Walker Posted July 18, 2006 Report Share Posted July 18, 2006 Just get some Heatsink Reds in CNC backings with a nice fresh grind - awsome. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted July 18, 2006 Report Share Posted July 18, 2006 Miles away form Plymouth then!!! BuggaSo you have checked all of what i did put in that list?? I rode some spoilt brats GU and it felt uber flexywhen i just hopped but the brake felt stuff, was boosterless Quote Link to comment Share on other sites More sharing options...
Synergy Posted July 18, 2006 Report Share Posted July 18, 2006 buy a booster because the gu frame does flex a bit also i found out when my girnd wanst working brilliant sand down the rim a wee bit with sand paper and then use zoo pads, works immense if your still not happy ad a bit of tar. Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted July 18, 2006 Author Report Share Posted July 18, 2006 im going to test out the zoo and the coust pads i think and ive got a booster so ill give that a go as well! Quote Link to comment Share on other sites More sharing options...
planet-x-boy Posted July 18, 2006 Report Share Posted July 18, 2006 My 26" GU flexes ALOT. I mean like 5mm on each side. So maybe thats the problem. i run an rb lever, braided hosing, koxx yellows, and soon to have a Gu booster. Works beasty. I would say get a Gu booster just because they are huge and the frame would never flex wth that thing on and just get some coust, koxx reds/yellows, or plaz all with a harsh gring and you should have a brake that will work awsome.Hope that helps!!!!Brett........ Quote Link to comment Share on other sites More sharing options...
mr_gubike Posted July 18, 2006 Report Share Posted July 18, 2006 Hey.....Ive got a 20" short gu and my rear brake its really good. I run a rear 06 echo rim on zoo pads with tar, nothing can beat it But my freind has the same set up but with a grind and his brake is slighty better, but his pads will run out before mine do so Abdab Quote Link to comment Share on other sites More sharing options...
mods Posted July 18, 2006 Report Share Posted July 18, 2006 Gu's have a built in booster i doubt you would really need two boosters, as that would be effectively what your doing. Quote Link to comment Share on other sites More sharing options...
bhups Posted July 18, 2006 Report Share Posted July 18, 2006 Zoo pads ***. Quote Link to comment Share on other sites More sharing options...
