Bb For Adamant A2?
Smallville
127.5mm is the best bet, however it depends exacty what setup you use.
Due to the tiny size of the frame, the main issue is crank arm clearance on the cylinders (rather than the chainring on the frame) - so if you use a really wide (38mm+) rim then you'll definitely need the 127.5mm.
However, as said above, give us a call if you're in doubt :)
Cheers
Adam
