Plaz Pad Problem.
Dan6061
Ok, I've had these Plaz pads for over a year now I think, and they've barely worn. :ermm:
They've been on several grinds, some of which have been quite harsh. And 3 rims.
They just don't lock.
I've got some Zoo pads at the moment, and they're wearing fast on my worn out grind, and at a funny angle. :(
So I wanna use these Plaz again.
I've tried de-greasing them before, and filing them down a bit to get dirt off, but still no luck?
Is there anything else I can try to get them back to locking like they used to?
I don't really want to have to use tar all the time, or keep grinding my rim.
They used to work super good, even on a worn grind!
Weird, I had 2 sets of plaz and both of them were very good ! on a grind of course, even when the grind was dead they were still offering a great performance !
You could try to put a fresh grind, put your pads on, and go down a hill holiding the brake a little bit, they will do a lot of noise, but I did that with mine and after that they were working very well ! make sure you don't hold your brake too long because the pads will surely worn out fater than usual ;)
what are you de-greasing them with? if its a car product then it could contain oil (to stop bits rusting)
give them a wash in soapy water, then normal water and let them dry out and try them, maybe file, grind off the top layer to get to new material.
i don't know but maybe if the pads have been to hot and too cold lots of times it effects the pad material, i expect they have just got old and gone very hard all the way through, because of gettin to hot and cold. No doubt u need to chuck em away unfortunately.
Edited by mods
Wash them in soapy water, to get all the de-greaser off. Then, once they are dry, take a file/piece of sandpaper and take 1mm or so away from the top. You need to this as when the pads are made they are finished off with a layer of thicker, more dense, material which is not very good... (Y)
Hope this helps!
Cheers,
Joe.
I rubbed my Plaz pads down on some rough sand paper first, then put them onto a medium ground rim and they work amazingly. :)
>>Sam<<
Cheeeeeerrss.
Did that earlier, spot of tar, works well!
And squeaaakkkssss!
