Handlebar/stem Creaking
RatherGood
I recently bought an Echo Tough bar and an Onza PZ31 stem, I have only had them for a couple of weeks and about a week ago I started to hear a creaking coming from the stem.
I'm not sure why, I have tried loosening (wasn't a good idea :P ) and tightening the handlebar clamp and the steering tube clamp but it still creaks when I put wight on the bars.
Any of you know why this is? It's really getting on my nerves...
EDIT: I have used the search by the way and all I found was handlebars slipping
Edited by RatherGood
Yes I thought it might be the headset as well, forgot to mention it's a Diatech D-cup and is as new as the bars and stem. I will give it a good grease later when i get to my bike (I leave it at a friend's farm, some good riding spots there).
I'm pretty sure the creaking is coming from the handlebars though :ermm:
Handle bars will just creak because of the flex and the pressure of the metals on the clamp. Try taking everything appart and greasing it up and then see if it makes much of a difference. This should stop things being in direct contact and hopefully stop the squeaking.
Yes that's what I thought it was, but wouldn't greasing the bars make them slip? :huh:
if you can hear and fell a creak from you hande bars that usually means they're ready to snap. i'd take your forks out give them a good check for any cracks, other wise just grease everything like everyone said.
Mine aren't ready to snap because I've hardly used them so I will just grease the bolts, WD40 the bars and see what happens, if it doesn't stop i'll just put up with it if its normal for the Echo bars.
Thanks for the all the advice.
The last time i encounted this problem i found my steerer tube to be slightly oval there for only gripping two points of the steerer tube thus being able to move which makes a creaking noise. It can sometimes happen by over tightening bolts, remember typical m6 bolts are only ment to be tightened to 8-12 Nm.
