Try-all Parts And Building
danfox23
from what i know it should fit as long as you get the right sizes for the frame
and
the bashring n plate are both different
used for different frames
i.e bashring are used on longer mod frames like a zoo python
:D
yer because other wise the bit where u stick the bashplate on would be use less
but it does seem cool to use have a ring on a frame that isnt suited
but i m not sure if that works
also it would be lighter
Bashrings and bashplates both do the same job, rings are more popular nowerday though I gess its just what the makers decided on. You can run both but whats the point just adds more weight. So its nothing to do with how long the frame is pythons used to have bashplates..
Forks should be fine as long as you buy what ever size you need for your wheele either 26" or 20", when forks come new the steerer tube normaly need cutting down but thats a 10 seccond job.
Most try all stuff should fit on your bike in reason so don't be a tit and buy 26" wheels for a mod frame... There maybe a problem with the bars just make sure both the stem and bars have the same clap size as if i rember Try all did some that only work in a certan try all stems a while back..
Sam
Edited by Swize
