Spoke Patterns!
Robwalker
Yeah, i orderd the spokes from tarty and they sent them, i tried building 3 cross, which i can do, but when i looked on the reciept it said they were for two cross pattern, i was just wondering as i learnt to build 3 cross by coppying another wheel, and i was going to give it a shot with this. Ive looked on that sheldon brown website but i couldnt find much. Thanks
Basically, assuming you're building it correctly, when you come to twist the hub, you just turn it a lesser amount, basically. The length of the first drive side and first non-drive side spokes you put in will mean you can only really spin it a certain amount, and then the length of the spokes you're putting in will basically make it pretty obvious which places they go in (Y)
Just try building it the "proper" way :) It's really, really easy, and you'll be set to build whatever lacing pattern you want afterwards. It's straightforward enough, and you get a good build at the end of it. If you go to www.gsportbmx.com and try and find the wheelbuild guide there you should be fine. If you can't find it, I can PM you how to do it or something (Y)
