Assembler Language
im using a PIC16F84A, iv got all the instructions(34 single words) just need help with writing the dam code :blink: what im doing is building a sensor cluster containing a micro switch, air flow sensor and a temp sensor. The micro switch is straight forward iv managed that. What i need help with is reading in the values from the other sensors and outputting when they change by a set amount as an alarm.
Im using Micro chips MPLab IDE to program the chip, which dont make much difference since its assembler code im writing.
When you google it the amount of crap you get is unreal, might have to buy a book :o
keep the ideas coming
cheers
