Strange Clicking...
Oddball
hey guys, I was out on my bike on Sunday, and I noticed a weird clicking coming from my freewheel/BB area, it feels like it only clicks when I put pressure on (like peddle hopping or wheeling to get on the back wheel...if you get me?) I hope I’m making sense here?
If you understand what I’m on about, could you please let me know what it could be, and if it’s bad, and what it is that is clicking.
Thanks very much.
Anf.
Also sounds like it could possibly be a pedal that needs greasing
Give them a spin and see if they spin freely or if there is a lot of resistance
Even if this isn't the problem, it's best to keep them clean and lubed anyhoo!
As suggested before, check all bolts etc. are done up tight enough, but don't overtighten things as this will cause just as many problems
Yeah - I've got the exact same thing...
I find that if you just tighten up the crank arm bolts, it goes away untill they loosen off again.
I never completely stop it though 'cause the bolt is MEGA MEGA tight and I don't wanna strip it...
Flipp
Get some grease....take your crank arms off...grease the tapers..whack your crank arms back on and tighten them up....and the clicking should disappear (Y) Hope this helps
zoo baby!
TAKE IT APART and grease it put it all back 2geva.tighten the right crankarm not to tight though otherwise ur freewheel rubs ur bb and then tighten the left 1 n giv it sunm beans
What? :blink:
might be the free wheel ! just put a screw driver in the hole in the side closest to the bb and push it forwards as in towards the forks ! if its not that one of ur crank arms might be nackard and hitting ur frame like one of mine does its dodgy and only does it when i turn or kick hard ! new crankas comin soon :):)
I would say: (if you can be bothered, takes a while to do)
Take off the cranks and BB, make sure there's no dirt in any of it.
Grease all the threads.
Grease the area of the BB where the removable cup touches onto main part.
Put everything back on, do it up nice and tight ;)
In my experience with mine and friends bikes, if that didn't stop it, the frame was cracked :( and you feel bad because you wasted an hour AND you need a new frame!
Hope some of that helps anyway, plus what the other people have said
Tom (or Sir Creakalot as I have been known...)
Edited by Tommy d
Put the BB in tight.
Put a lot of grease on the crank tapers.
Tighten the cranks on well (if ISIS) but not super tight (taper, 'cos you'll splay the tapers).
Wipe away any excess so you don't attract dirt and grit to the interface/taper.
Couple of additions.
Clicking like that is generally just a tiny amount of play between two dry surfaces. Just work through your crank area lubing as you go, and 9 times out of 10 it'll sort it out. It tends to be just the tapers/ISIS interface needing to be lubed up :)
