Help
' Mart '
i recently swapped my monty 221 ti for an onza zoot,
but i wanna get a new rear wheel so i was thinkin of gettin an echo fixed rear hub,
but i have a question would a freewheel screw onto this hub, as id run an eno on the rear and my tensiles up front,
Link To Hub
would the gearing be affected at all as im running 22 front 14 rear but what would 22 front 18 rear be like??
thanks for any helps cheers
i had an idea would i be able to run a front freewheel system on a 26",
if i take the 22 tooth cog off the front and run an 18 tooth eno, what sort of sized rear sprocket sould i be looking at on the rear.
thanks.
thanks.
You should be looking for a 16, 15 or 14.
I'm currently on a 16t and I find it way too spinny, I would have gone for a 15t.
(Y)
A freewheel will screw onto the hub. Says so inthe description. :turned:
Description
- Fixed rear 26" hub from Echo.
- 135mm axle spacing fit all modern 26" trials frames.
- Includes 15mm Low-Profile Hollow Stainless Steel Allen Key bolts.
- Large diameter fully sealed cartridge bearings (like Chris King), with a 7075 CNC machined 15mm axle for maximum strength:weight ratio!
- High grade 6061-T6 CNC Machined hub shell.
- Threaded section ready to fit a freewheel or fixed sprocket. 15 or 16T recommended for 18T front freewheel
- Super wide flange spacing offers the strongest wheelbuild possible.
- Available in Black, Silver, Red, Blue, Green and Gold!
- 32h only.
- Weight: 227g including bolts and washers!
