Cheapest T-bird
(Above)
I am intrested in buying one for around 50 pounds.I heard that the cheapest one was a 2000 with v brakes and the thin rear wheel.
i would rather save up for bit longer and buy t-pro, i can guarentee you that afyter about 2 months of having a t-bird, you will want to get a t-pro..
JK
i just was lookin on ebay and i rembered the trials bike da bomb i know there not ver y good but there cheap.Plus beacuse i am a learner i may as well get a cheap bike.The da bomb was 30 pounds no bids or 50 pounds no bids but with hs 33's.If i do get it at least i can buy just a new frame when i get beter and build it up with the parts of the da bomb.
that sounds a good idea to me. My friend had a da bomb, he rode it for a few years :S but he has just brought a t-pro frame and fork and put his da bomb bits on. The only thing is, I think the Da Bombs run a 14mm rear axle whereas pretty much all current frames, run a 10mm axil >_< . If you are willing to spend a bit of money when you get a new frame then go for the Da Bomb, If not try for a t-bird or even better a t-pro.
