Any Way Round Not Having Evo;s
N Roach
only way i can see it happening is a four bolt mount that somehow screws into the holes for the canti bosses but ive never seen such an adaptor made to fit 26" wheels but Mr Heatsink himself did make them for his 24/26 inch........
his were v to v adaptors to run 24
sounds like it would be pretty easy to solve, essentially a plate with the 4 bolt mounts on that bolts on via the v brake boss holes
or do the right thing, get a proper brake by running a v ;)
run a steel maggy booster?
then a v brake booster on the actual v mounts?
if you are after a booster i have 2 badically brand new rb v brake boosters i bought, but never needed as my bonz adaptors were far better than i thought they would be :) pm me if you are interested
  chocolate_bikes said:
is there any way around not using evo mounts on v-brake mounts, i think i have seen a device that sits on top of the v-brake mount, please help
Let me get this straight, you want a device which sits on a canti boss and holds a slave cylinder in place? Isn't that *exactly* what an Evo mount is for? Why are you so against using them?
