Pauly Posted July 6, 2006 Report Share Posted July 6, 2006 hey there im just about to purchase a avid bb7 but i am in need of a brake cable for the front .. i want one that i know isnt going to cause alot of flex to the lever and not cause alot of friction.. also i dont realy want to spend over 10 quid for a cable.... urm i would like to buy it from crc so could someone point me in the right direction for a good cable from this link CRC cables, from past experiances that would be great Cheers Pauly Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted July 6, 2006 Report Share Posted July 6, 2006 Odyssey Linear Slic cables are really good, i've ran a few when used to run a Rear V, they can take enough shit and give the lever alot more stiffer feel than normal Cables. There not majorley expensive either witch is good, and come in shitloads of Colours.There not on CRC though but still you can get them front your local LBS or skate shop what sell Bmx stuff. Quote Link to comment Share on other sites More sharing options...
RicH_87 Posted July 6, 2006 Report Share Posted July 6, 2006 Odyssey Linear Slic cables are really good, i've ran a few when used to run a Rear V, they can take enough shit and give the lever alot more stiffer feel than normal Cables. There not majorley expensive either witch is good, and come in shitloads of Colours.There not on CRC though but still you can get them front your local LBS or skate shop what sell Bmx stuff.www.alansbmx.com Quote Link to comment Share on other sites More sharing options...
Janson Posted July 6, 2006 Report Share Posted July 6, 2006 XTR isn't bad either, and cheap at CRC. Quote Link to comment Share on other sites More sharing options...
Pauly Posted July 6, 2006 Author Report Share Posted July 6, 2006 ok i ended up gettng the xtr cable.. cheers lads, the topic can be closed now ..Pauly Quote Link to comment Share on other sites More sharing options...
