brendan@medway riders Posted July 6, 2006 Report Share Posted July 6, 2006 hi i was just wondering would some zoo bars fit in a onza stem i got the steam of a t mag if that helps cheers Quote Link to comment Share on other sites More sharing options...
S-town Ollie Posted July 6, 2006 Report Share Posted July 6, 2006 (edited) It depends on what size your stem is as the zoo! riser bars are oversized bars and the onza stem may not be largenough for the bars to fit into. hope i helped Ollie Edited July 6, 2006 by S-town Ollie Quote Link to comment Share on other sites More sharing options...
trials rules Posted July 6, 2006 Report Share Posted July 6, 2006 If it's the latest T-Mag then the bars will fit because the stem is for oversized bars. If it's an older model give someone like Supercyclesa ring as they are the main dealers Dan Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted July 6, 2006 Report Share Posted July 6, 2006 If it's the latest T-Mag then the bars will fit because the stem is for oversized bars. If it's an older model give someone like Supercyclesa ring as they are the main dealers DanThey wont fit in the stem which comes on the new t-master, but if you have the stem off the old t-master then it will. Reason being the zoo bars are 31.8, so in order for it to fit you will need a 31.8 size stem. Dan. Quote Link to comment Share on other sites More sharing options...
Egg Fried Rice Posted July 6, 2006 Report Share Posted July 6, 2006 It depends on what size your stem is as the zoo! riser bars are oversized bars and the onza stem may not be largenough for the bars to fit into. hope i helped Ollienever put "hope i helped", you will never get validated.JK Quote Link to comment Share on other sites More sharing options...
joshywa Posted July 6, 2006 Report Share Posted July 6, 2006 never put "hope i helped", you will never get validated.JKdont put "JK" people will get pissy at you Quote Link to comment Share on other sites More sharing options...
poopipe Posted July 6, 2006 Report Share Posted July 6, 2006 hi i was just wondering would some zoo bars fit in a onza stem i got the steam of a t mag if that helps cheersno, won't fit . the standard t-mag/t-pro/etc. stem has a 28.6mm clamp. zoo bars are 31.8mm. I found the t-master stem with zoo bars was an easy change from standard onza bar/stem. There wasn't much difference in height/reach once I'd messed around with bar angles n stuff so i got used to it all pretty quickly.OT...I wish people would stop posting handy hints about getting validated, there's a big list of rules at the top of the page, a sticky thread with tips in and (god forbid) common sense to help people out with that. Quote Link to comment Share on other sites More sharing options...
brendan@medway riders Posted July 7, 2006 Author Report Share Posted July 7, 2006 If it's the latest T-Mag then the bars will fit because the stem is for oversized bars. If it's an older model give someone like Supercyclesa ring as they are the main dealers Danthe stem is off a 05 t-mag Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted July 7, 2006 Report Share Posted July 7, 2006 the stem is off a 05 t-mag yeah, Unfortunatley the Zoo bars wont fit, because of the different clamp sizes.If you get a stem like th Echo team, then they will fit. And will be around the same height as your current bar and stem.Team stem: Quote Link to comment Share on other sites More sharing options...
ned1 Posted July 7, 2006 Report Share Posted July 7, 2006 hmmmmm i have just bought a t-mag and a zoo! riser bar fits on my stem ...although they are different from standard i think. Quote Link to comment Share on other sites More sharing options...
