aener Posted July 6, 2006 Report Share Posted July 6, 2006 As said, I have very little money, but I need a WIDE 19" rear rim. Only got a thin, 20" at the moment. :$ I've been building up a T-Pro (got frame for £80 which started it) - but my rim isn't wide enough for the maggies to lock on properly. Question is - can I get a 48 hole, super wide rim? I've been told i need an Onza Hog, or a TryAll, or a Koxx one, like - 47/48mm wide. But they only come in 32/36 spokes.I need 48 'cause that's the hub I've got (again, no money for a new hub).Also, the spokes at the minute cross over 3 others before hitting the rim, so I guess they'd be X3? Would they fit in a 19" rim or would i need new spokes aswell?'Tis kinda urgent 'cause I can't ride with confidence untill the brakes work Unless, is there another way to bring the brakes in further? I've got them all the way in on the clamp things already, and got them bled about a week ago, the red twisley knob on the lever is all the way in (or out - whichever you call it to make it go in further) - but it still only touches the rim when the lever's like, nearly on the grips... Any help is much appreciated (sp?)Cheers, Flipp Quote Link to comment Share on other sites More sharing options...
adamtrials Posted July 6, 2006 Report Share Posted July 6, 2006 There is no such rear rim i dont think...Your best bet is to just get a cheap secondhand hub/ wheel or get a genius to lace48 hole hub to 36/32 hole rim... Quote Link to comment Share on other sites More sharing options...
Egg Fried Rice Posted July 6, 2006 Report Share Posted July 6, 2006 There is no such rear rim i dont think...Your best bet is to just get a cheap secondhand hub/ wheel or get a genius to lace48 hole hub to 36/32 hole rim...i think he means 48mm wide.JK Quote Link to comment Share on other sites More sharing options...
aener Posted July 6, 2006 Author Report Share Posted July 6, 2006 Well I meant both It was supposed to mean 48mm wide - AND 48 hole... But it looks like I need to spend a bit more money...Suppose that answers questions about the spokes too, no?Thanks anyway...Flipp Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted July 6, 2006 Report Share Posted July 6, 2006 And also, do you know where I can GET the spokes from? Preferably the right size I know most stuff about bikes now 'cause most everything's gone wrong with mine, but with wheels i'm a noob. Give Tartybikes a ring.They're bound to be able to help you out with spoke lengths, and they probably have them in stock.They had the spokes for my Profile hub on Kris Holm rim. Quote Link to comment Share on other sites More sharing options...
aener Posted July 6, 2006 Author Report Share Posted July 6, 2006 (edited) ...Posted and doesn't matter any more... Edited July 6, 2006 by Flipp Quote Link to comment Share on other sites More sharing options...
poopipe Posted July 6, 2006 Report Share Posted July 6, 2006 i'm pretty sure you're screwed on the 48 hole 19" rim. If you could persuade a shop to sell one to you seperately or find one second hand it probably wouldn't cost much to get a t-pro rear wheel. They're a hog with a cheap onza unsealed hub - mines lasted over a year and it's only got one dent in so they aren't shite.a lot of people glue extra material into their pad backings so they'll reach thinner rims. I've not done it so can't help you out with details. Try the search on here. Quote Link to comment Share on other sites More sharing options...
