Shinny T-pro
hicks
For the love of god, please take that fecking 'thing' out of your signature. Your thread is about the size of a 300 replied post when you only have 2.
Edit: Oh, and its rubbish :)
Edited by anzo
The Onxa T-pro s anodized. You can't use any chemical remover on it. Well non you can get.
Go get a drill, a wire brush attcment or one for the anle grinder. Brass is good a sit's soft so the frame won't be pitted. use this all over to remove the anodizing. Then once doen clean off with boiling hot water from the kettle. The dry. The polish like made till mirrord. I'll try and get a pic of my head tube on my t-pro i just modded and thats now polished
No you can use nitromors that will strip the paint of anything. its as easy as 1,2,3
1. Take all components of frame ( or leave them on if your special)
2. Apply an even layer of nitromors over the frame ( or just the parts u want to be stripped)
3. Leave for about 12-24 hours then wash away.
Never tried it before on a frame bu i did do it on my brake booster and it turned out fine, but i have been told it will work on frames as well as thats how i got told to strip mine but then i cudent be assed lol.
Hope i helped
Daniel
Hope i helped
Daniel
Its not paint...
And people stop saying "hope i helped" it is not going to help getting you validated.
I think the drill thing would be easier on a frame, caustic soda made a right mess of Bigman's King rear hub and could make a right mess of your skin...
Edited by adamtrials
it says on the back of the tin not to apply to the frame all over, work in little sections of the frame at any 1 time. also you dont "leave it for 12-24 hours then wash away" as it also says to leave it about 10-20mins (something like that)
IT'S ANODZIED YOU NOB NOT PAINTED
i think that's what you meant :P
nitromors will not take the green stuff off, it will only remove the laquer and the decals
caustic soda is ok - as long as you follow the instructions, wear appropriate safety gear, remember not to drink it and dispose of it safely.
I'd be surprised if using caustic soda didn't void your warranty - given that it eats aluminium - an onza warranty is a precious thing (cos it's actually worth the paper it's printed on)
Edited by poopipe
