Pretty Much Have My St-1 Speced Out.
justfuzzit
-Simtra ST-1 frame (ordered)
-Avid BB mechanicals front and rear (until I get some hss3's)
-XT levers
-Simtra mcpudgy handlebars (ordered)
-Truvativ holzfeller crankset
-Specialized lo-pro mag II pedals
-Alex DX32 rear rim
-Dont know what rear hub, maybe hope.
-Havent decided on a front wheel yet. (not too worried about it)
-Specialized chunder s-works tires
-Echo urban fork.
-KMC X9 chain
-Specialized enduro grips.
-FSA orbit xtreme (had it around)
-shimano xtr rear derraileur. (got one laying around) or maybe a sram XO if i can fix it. (found one in parts in a bag)
-Probobly gonna throw a thompson stem on there, maybe titec.
-Sram rocket shifter (for xtr) or sram X9 shifer maybe XO. depending on what i can use.
Il post pics when it comes in.
What do you think?
id chnage the levers get xtrs
cranks get echos
get a pro 2 rear hub
sack the tyres off get some maxxis
hope xc on ewcho rim for front wheel?
sack the chain off get a kmc kool
get a sora/105 mech
With the levers, Whats the main difference between XT and XTR? Cause XTR is significantly more expensive.
I already have the cranks.
I already have the tires laying around.
Yeah Pro 2 hub, good idea. Il probobly go with that.
Kmc kool, il check it out. I have some X-9's around but the kool might be better.
Yeah i probobly shouldnt throw an XTR rear derraileur on there. Probobly grab a 105.
Thanks for the advice!
Edited by justfuzzit
erm arnt xt levers a bit uncomfy, xtrs jsut feel nice, but so do those kool avid levers with a tpa. which can be used either way around, what they called?
Ultimates? or might be SD7 or something like that? :S
Edited by the judge
XT are exactly the same as xtr bar a few grams and the colours. :P
They're not. They are pretty different. They both have the same shape (very nice IMO), XTRs have better bearings, which means that XTRs will probably last forever. XT levers will die after a few years (mine lasted about 4 years before the bearings pretty much died), but that's still a fair old time. The only other thing is the speed-dial thing. On the XT levers there's only 3 different positions and it's fiddly to change it, whereas on the XTRs you've got full control like on the Avid levers.
To be honest, XTRs are a bit nicer, but it's up to you as to whether it's worth paying nearly double the money.
SD7 levers are probably better value, but I never really got on with the shape, so I'm gonna recommend Shimano (Y)
