eskimo Posted July 3, 2006 Report Share Posted July 3, 2006 I'm looking into getting a Echo freehub. A Echo rim, Echo sprocket and I've already got some echo cranks.I'm currently running a Viz hub, Viz Sprocket, Viz rim and a Eno freewheel.I'm so fed up with the chain going slack then tight and having it bounce all around! Even the Eno holds nice its such a pain. So your thoughts on my current setup and the new setup...Thanks again! Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 3, 2006 Report Share Posted July 3, 2006 The reputation of the Echo hubs in general here is pretty negative, and that's putting it f**king mildly. To be honest, I'd wait at least 6 months before buying one of those Echo freehubs. Let the early customers (sorry, I meant test riders, I forgot it's a Deng product) have to deal with spending loads of money on a hub that's going to blow up. If they blow up - you've saved money. If they don't - buy one if you want one. Just gotta hope they learn to use bearings that don't explode, axles that don't shear, and pawls and ratchets that work without dying. Not too much to ask Quote Link to comment Share on other sites More sharing options...
Mr_Pitbull Posted July 3, 2006 Report Share Posted July 3, 2006 I think Mark hes on about buying it off Tom Tom, as there was only ever 1! Echo Freehub in the world and it was mine (before selling it to Tom). its impossible for the Echo freehub to blow up, it skips for 1 reason, and thats due to its spring mecanism coming loose. Once the springs tight its perfect ! until it comes loose again. Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 3, 2006 Report Share Posted July 3, 2006 I'd still rather not have that problem with a hub, ever. Plus the way that all other Echo hub axles snap is a bit disconcerting? I guess if you want an "exclusive" rear hub you could give it a try, but I'd rather just go for a Profile or something, or just try and work out what's giving you grief with your current setup? Quote Link to comment Share on other sites More sharing options...
dicko1607 Posted July 4, 2006 Report Share Posted July 4, 2006 I ONCE READ A POST WHICH SAID THE FOLLOWIN" I HEAR SOME OF THE COMPONENTS ARE MADE OFDYNAMITE COS THEY LIKE TO GO BANG!!!!"NUF SED MOI THINKS Quote Link to comment Share on other sites More sharing options...
poopipe Posted July 4, 2006 Report Share Posted July 4, 2006 I ONCE READ A POST WHICH SAID THE FOLLOWIN" I HEAR SOME OF THE COMPONENTS ARE MADE OFDYNAMITE COS THEY LIKE TO GO BANG!!!!"NUF SED MOI THINKS ? Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 4, 2006 Report Share Posted July 4, 2006 Hahaha, that was the first thought that went through my head when I saw the username too Quote Link to comment Share on other sites More sharing options...
dicko1607 Posted July 5, 2006 Report Share Posted July 5, 2006 not the same dicko fool this used to be my mates profile he had the last name Dickens and shortened it now i have taken over but cant work out how to change the name yet ?????????ne1 know Quote Link to comment Share on other sites More sharing options...
tom tom Posted July 5, 2006 Report Share Posted July 5, 2006 I think Mark hes on about buying it off Tom Tom, as there was only ever 1! Echo Freehub in the world and it was mine (before selling it to Tom). its impossible for the Echo freehub to blow up, it skips for 1 reason, and thats due to its spring mecanism coming loose. Once the springs tight its perfect ! until it comes loose again.as it says, works fine, i have even tighted the spring up amazingly tight, nice and loud and doesnt skip, also its the origonal 72 eps version, can only by the 48 eps version.tom tom Quote Link to comment Share on other sites More sharing options...
