Echo-Scott Posted July 2, 2006 Report Share Posted July 2, 2006 Hi, This may sound like a stupid question but I am woundering if an Onza square taper bottom bracket will fit in an echo team frame or will i need a new bottom bracket or any diffrent parts for the bottom bracket to make it fit into the frame?ThanksScott. Quote Link to comment Share on other sites More sharing options...
Alastair Posted July 2, 2006 Report Share Posted July 2, 2006 If you are meaning the Onza Bottom Bracket off TartyBikes then yes it will, if you bought the right size. If size of the Bottom Bracket is 127.5 then it will fit perfectly, but if you bought the 119mm axle then i dont think it would be wide enough, yes it will fit your frame, but your crank arms would rub on the chain-stays and then you wouldnt even be able to ride your bike.If you have already bought a 119mm axle one and you havent used it then speak to TartyBikes or wherever you bought it from and im sure they will be happy to replace it with the wider one.Al Quote Link to comment Share on other sites More sharing options...
Thurston Posted July 2, 2006 Report Share Posted July 2, 2006 Scott you shud have askedNo it wont fit, it will be like my old one on the monty, to short.Buy a 127.5 one from tarty while your gettin your other stuff Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted July 2, 2006 Author Report Share Posted July 2, 2006 Thanks guys, Ill get a bigger bottom bracket when I buy my new stuff for my bike. Thanks again Scott Quote Link to comment Share on other sites More sharing options...
