Onza T-pro Snail Cams
Joey B
I've just been out to have a look on my old T-pro for you, and i don't think the holes are for snail cam bolts. I also compared it to my GU, and i think to run snail cams the actual hole you are looking at needs to be threaded so an allen bolt can be screwed into the frame and on my T-pro there is no thread.
So to answer your question no i don't think they are for snail cams (but i maybe wrong) :ermm:
Edited by huck_it
Sorry for the silly question but what are the snail cams for? thanks
They are snail shapped disks that go on the axle and are pressed against a bolt to keep chain tension
IPB Image
Here's them on a trials motorbike (couldn't find any pictures for push bikes)
You have to loosen the two axel bolts off, you then turn the snail cam and due to the shape (they get wider further around, hence the name snail cams) you turn it so it pushes your back wheel backwards causing the chain to become tighter. (Y)
Edited by huck_it
Nah you dont need a guide its simple really. in each of the holes you screw in a allen bolt. when you have done that you take the nut off of each side of the axle and slide a snail-cam on. Then all you do is rotate the snail cam until the chain is tight, and screw the nut back up tight.
Edited by fugigas
Is there any chance of one of the cams coming loose and wont stay tight?
Nope because it is wedged against the mount and when you tighten the wheel bolts it gets squashed between the frame and the wheel (if you run them on the inside)
excellent what snail cams are you using and do they keep the tension or do you have to readjust them often??
get monty one, i have them on my zoo, and the little ridges make it easy to get your wheel in the right place, plus i think they are cheeper than koxx ones. koox ones are just cheep and nasty looking
im using the inspired ones from tartybikes, havent been out much since i got them but while i have been out they dont seem to move and i never had to readjust them.
those are the smooth steel ones right ?
the steel ones are good, i've been running them for quite a while now with no hint of a problem.
I'm not convinced by ally ones cos they tend to take a bit of a kicking and since ally is shite soft they probably won't last long.
yep they are, they work alot better than i thought they would, i thought they would be slipping and need tighting everyday, but they are actually quite good.
great thanks guys i've had a look at a the few that are available and i've decided to go for the black koxx ones, mainly because i've never known koxx make a bad product but also because the black will go with my black and gold colour scheme.
Edited by fugigas
the 06 echo hubs come with the snail cams right ?
so if i just get sum allen key bolts the same size as the hole in my frame and just screw em in and turn the snail cams then do the hub bolts up tight it'll hold the tension ????????
thanks for any help
:D
