3rider3 Posted June 28, 2006 Report Share Posted June 28, 2006 rite i hav recently bought a new zona zip with rear hs33 it was asmsing to start with but wnt ridong about 3 days later brake was sliping easily so i rebled it put tar on rims sorted out tpa and it has a ground rim and its still rubbishcan anybody help me out on what to do?? or whats wrong Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted June 28, 2006 Report Share Posted June 28, 2006 have you set your pads up so they touch the rim when you pull the lever in what pads you got mate? Quote Link to comment Share on other sites More sharing options...
3rider3 Posted June 28, 2006 Author Report Share Posted June 28, 2006 wel i had koxx reds in but there wasnt much pad left so we tried normal magura pads and they are basicly brand new and the pad rubs the rim because it so close shal i put the old ones back one and move the pad very close again? im taking the magura to lbs tomo to see what they think but its quite strange? Quote Link to comment Share on other sites More sharing options...
the judge Posted June 28, 2006 Report Share Posted June 28, 2006 If you've got standard magura blacks in at the moment then that'll be your problem, they're not very good. Stick your koxx reds back in and your brake should be fine again. Quote Link to comment Share on other sites More sharing options...
3rider3 Posted June 28, 2006 Author Report Share Posted June 28, 2006 ye but it was stil the same problem with the koxx reds on and theres like a mm of pad left it feels like i cant get no power out of the lever neway im getting plazmatic crm yellows on friday so might solve the proble?? Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted June 28, 2006 Report Share Posted June 28, 2006 thats not the prob!.. its that there is no power behind the break! post it correct next time tim! soo anyone got a solution?? also there is no movement in his break until the lever is half way in? are the pistons pooped? Quote Link to comment Share on other sites More sharing options...
Rab Posted June 28, 2006 Report Share Posted June 28, 2006 Could it be that there is some air in the hoses and the brakes need a good bleed.You could have the best pads in the world and it still wouldnt have much power. Quote Link to comment Share on other sites More sharing options...
gr8grumble Posted June 28, 2006 Report Share Posted June 28, 2006 no i bled it well! hmm... the brake doesnt respond till the lever blade is pulled back half way? Quote Link to comment Share on other sites More sharing options...
willwithashton Posted June 28, 2006 Report Share Posted June 28, 2006 Your brake might need bleeding, i cnt think of anything else it could be. Quote Link to comment Share on other sites More sharing options...
anzo Posted June 29, 2006 Report Share Posted June 29, 2006 Dismantle the brakeBlast all the hoses out with an airlineThrow it all in a bath full of waterShake all the parts to fill them with water and get any air outRebuild the brakeLeave the bleed bolt off the piston and lever, pump the lever like made, occasionally holding your finger over a bleed point/hole/thread or whatever you want to call it.Put the bolts back in.Done.Note To Retards:Always keep the WHOLE system UNDERWATER otherwise you'll just fill it with air again.Your problem sounds like its a trapped air bubble around the lever area (if the pistons are coming out at the same time). Resulting in a shitty brake Quote Link to comment Share on other sites More sharing options...
sunn_bmixx Posted June 29, 2006 Report Share Posted June 29, 2006 set up the pads so they hit at the same time, If one pads is getting stuck out, which maybe the problem you need to clean the piston, note: with care!!!! dont use too much oil and just fiddle really.Ian Quote Link to comment Share on other sites More sharing options...
unicycle boy Posted June 29, 2006 Report Share Posted June 29, 2006 Check the crosover tubing is put in right, I had mine in wrong for about a week before i realised :$ That resulted in me have a rather terrible brake. Quote Link to comment Share on other sites More sharing options...
BIG L Posted June 29, 2006 Report Share Posted June 29, 2006 (edited) This could be a few things. I have had this on both of my maguras. 1) Your pistons could be dirty which stops full movement, what i did to clean them is, take the brake off wash the pistons with water and a cloth and then what i did was apply a thin layer of vaseline to the pistons and now they work fine.2) Also this could be you have not set them up correctly. I had that on saturday and couldn't figure out why one side was stiff and not moving, then i thought what if they aren't set up right and i know a trick if you put a 2p coin between the rim and pads that is the perfect spacing, after i had done that it worked again .3) Or it may be that it the brake needs bleeding as it has pockets of air in the lever or hoses. You can buy magura bleeding kits they cost around £20 but they are very simple to use they come with all the tools and oil. Or you could do what anzo said bleed it in the bath but make sure you don't use water in the winter as it may freeze!Although the other thing if non of this works it probally means the brake is broken you can do every thing to it, but if it's broken non of this will work and you might have to buy a new brake!Hope i've helped! Edited June 29, 2006 by BIG L Quote Link to comment Share on other sites More sharing options...
anzo Posted June 29, 2006 Report Share Posted June 29, 2006 Or you could do what anzo said bleed it in the bath but make sure you daunt use water in the winter as it may freeze!Unless you make it with a cocktail of Anti-freeze...shaken, not stirred. Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted June 29, 2006 Report Share Posted June 29, 2006 (edited) And for those who didn't understand.......Right, I have recently bought a new zona zip with rear hs33. It was amazing to start with but when i was riding about 3 days later, the brake was sliping easily. So I rebled it and put tar on the already ground rims and sorted out the tpa but it's still rubbish.Can anyone shed some light on this problem and help me to fix it???? a slightly clearer version!!!!it's possible that your pistons are bottoming out before the pad makes contact with the rim. Just reblead it and make sure there's no air in the system and you have the tpa right off when you bleed your brake. Edited June 29, 2006 by Gavyn L Quote Link to comment Share on other sites More sharing options...
Clawz114 Posted June 30, 2006 Report Share Posted June 30, 2006 First things first...use the spell check It took me about a minute to read your post when it should have taken around 20 seconds. If you want a chance of being validated then correct spelling is essential.In answer to your question your best bet is to bleed your brake in a bath as anzo said, and then do the 2p trick. Also are you tightening the bolts up enough, when i first got maguras i didn't tighten them enough allowing the pistons to slowly ease away from the rim everytime i braked heavily.Dan Quote Link to comment Share on other sites More sharing options...
