Which Is Best Way Of Spraying
N Roach
i did my bike like this
1. 3 coats of primer
2. leave in warm dry place for 24 hours then sand the primer surface to roughen it up so the paint grips better.
3. 4 coats of paint
4.leave for 24 hours again
5.3 coats of laquer
6. leave for another 24 hours
leave about 1 hour each time you put a coat on (Y) and if your gona psray it outside do it when its not windy and the weather must be hot.
thanks
John Kan
Edited by J-KAY
does anyone know how much it costs about to spray a mod frame ... its bair metal at the moment so will need primer paint and laqua
cheers
I think Halfords usually do a 3 for 2 deal on spray paints - They're usually £4.99 each. So you can get 1 primer, 1 colour and 1 laquer for a tenner. You *might* need another can of colour though (If you want to get it perfect), so that would be an extra £5. So £15 max.
if you were to have someone professionally spray your frame for you, then look at about the 80 mark. this is including full preparation. alternativly, find a professional car sprayer, and wait for the next batch of powerdercoating, and if there is any pain left over, ask them to do your frame, this works as long as you dont really mind to much what colour.
toby
