I Have A ?
Thurston
Right so heres the story, i bought a set of echo easys second hand, the steerer is way to short.
Would it be safe to get a really long stem bolt and run it like that
Or would the bolt snap under all the pressure and with it being so long
Cheers Thurston
i don't want to buy another stem, i only just got the zoo one today, along with these forks
I might buy the Zoo! one if you were to sell it though... (maybe)
P.S, i have a monty stem, with a small steerer clamp... type... thing :ermm: Yeah.
Older style monty..
In silver! :P
Man, i have just edited 4 times in 30 seconds :| lol
Edited by terror-error
maybe if you do risk braining yourself and run it, you could put in a cuttoff from another steerer on top of the real steerer - give the top bolt summut to go at - you could even bolt it on with a slightly modified bmx stylee star nut arrangement then do up the whole thing with a headlock thingmy .... ?
but
still a dodgy thing.
Older style monty..
In silver! :P
I'd rather just headlock it until i can get new forks
I heard about someone on here, increasing there steerer, with some nifty machining and stuff? ill have a look for who it was
Me?
Like you, I bought some second hand fattys and the steere was about an inch too short.
I really didn't want to sell them as their rare forks and these were in mint condition.
My dad had a clever idea to make up the extra length.
He made an insert peice from steel tube that slotted in the steere as the bottom was machined down, then it was welded all around the edge and made smooth like normal. Then drilled the middle out and it was perfect.
Did a really good job as he took them to work and sorted it all there, i've been running these forks for about 2/3 months and no problems at all so far (Y)
IPB Image
Me?
IPB Image
Sounds easy, its getting someone to do it
Those fork's of rob's have a steel steerer tube though, so it would be a lot easyier to increase the length.
would probably be a bit sketchy with easy's because of the aluminium steerer, finding a tig welder may be hard, and if the aluminium of the steerer is heat treated then u'll have thurther problems aswell as it will cock up all the properties of the metal.
Yeah going from a king to an el cheapo isn't something i'd have thought you'd be inclined to do.
My old forks were so cut down it only clamped using the bottom bolt, i just made sure the bottom bolt was done up very tight indeed and that the top cap bolt was tight as well.
That was untill my mate had the brilliant idea of bodging it. What we did was get another piece of steerer tube and cut it to the correct size so that there was enough steerer tube up the inside of the stem clamp.... so the piece was about 3/4 of an inch long.
We then placed this piece of steerer tube into the stem while it was attached to the rest of the steerer tube in the frame and tightened up the stem bolts. The fantatsicly unusual next bit was to carefully hammer a second star fangled nut into this new piece of steerer tube so there was a star nut in both the new piece and the steerer thats attached to the forks. Once it was in place we tightened the topcap bolt up through both star fangled nuts and is seemed to last very well indeed. Well the forks snapped at the bottom of the steerer before the bodge broke ;)
How long did they last for after you bodged them?
