Brake Boosters
They stop the frame flexing whe the brake is on.. if the frame flexes the brake is spongy..not good! some works better than others because of the design i suppose.
Edited by mods
when the pads push against the rim, they push with such a great force that the frame pushes outwards and this gives your brake a spongy feeling. a brake booster fits on your brake mounts, there like a brace i supose. they stop as much of the flex as they can. im running a echo 2 bolt booster and have found it to be great. it has really stiffend my brake up, its the same as the 4 bolt one really so i would recomend ither one of them.
