Bmx Question - Gyro
PaRtZ
OK my question is, is it possible to run a gyro on a frame that doesn't have gyro tabs welded to the frame? Im sure it is because my old bmx didn't have them, but it had this thing which went inside the headtube and gave the tabs for the frame
Could anyone link me to a product which can do this?
Thanks
If you buy a gyro it comes with everything that you need to install it.
The plate that you are talking about, comes with all gyro's weather you use it or not.
The plate is installed under the headset cup, you need to remove the top headset cup then place the gyro tab plate then reinstall your headset cup.
If you already have a gyro, and don't have the tab plate, i'm not sure that you can just buy the plate alone.
Matt.
