BIG L Posted June 19, 2006 Report Share Posted June 19, 2006 I have had my onza t pro for nearly 3 weeks now. I have noticed when i pull the brake hard (E.G When i'm doing rails) the frame flexes so the question is can you fit a brake booster with a four bolt mount set and what booster should i get for under £15?I will appreciate any help.Cheers BIG L Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 19, 2006 Report Share Posted June 19, 2006 You won't be able to buy a booster for under £15, unfortunately. I think they're pretty much all £25-30 or so, so you may have to save up a bit more unfortunately, or keep checking eBay.Most modern boosters will fit 4-bolt Maguras. Magura's OEM boosters only do 2-bolts though, and they're not even that great for them. Try and look out for any of the Echo, RB or similar boosters Quote Link to comment Share on other sites More sharing options...
BeNNy Posted June 19, 2006 Report Share Posted June 19, 2006 Think the cheapest one you can get is probably Echo 4-Bolt for £20 Quote Link to comment Share on other sites More sharing options...
T-Max Posted June 19, 2006 Report Share Posted June 19, 2006 (edited) The cheapest on the market (i think) is the Magura Evo 2 at £12. I bought one for mine cos I'm on a tight budget at the moment and it works fine!http://www.chainreactioncycles.com/Models.aspx?ModelID=9445Cheers Edited June 19, 2006 by T-Max Quote Link to comment Share on other sites More sharing options...
nigel@hull_trials Posted June 23, 2006 Report Share Posted June 23, 2006 get the new zoo,adamant,czar,gu booster Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted June 23, 2006 Report Share Posted June 23, 2006 rb 4 bolt boosters are £15 from ebay check it out Quote Link to comment Share on other sites More sharing options...
tom tom Posted June 23, 2006 Report Share Posted June 23, 2006 The cheapest on the market (i think) is the Magura Evo 2 at £12. I bought one for mine cos I'm on a tight budget at the moment and it works fine!http://www.chainreactioncycles.com/Models.aspx?ModelID=9445Cheers they dont work for shit, you can bend them with your hands Quote Link to comment Share on other sites More sharing options...
M3LLON_t-mag Posted June 23, 2006 Report Share Posted June 23, 2006 just a word of advice dont go with an Echo booster on a T-pro or T-mag i had one on my t-mag and lets say it nearly destroyed my 4bolt not enough spacing on the booster Quote Link to comment Share on other sites More sharing options...
tom tom Posted June 23, 2006 Report Share Posted June 23, 2006 just a word of advice dont go with an Echo booster on a T-pro or T-mag i had one on my t-mag and lets say it nearly destroyed my 4bolt not enough spacing on the boosterthe idea is it is ment for mod's and it has always worked fine for my python and other riders i ride with, how do you know or was it just that 'you' shitted it up? Quote Link to comment Share on other sites More sharing options...
