My Base
Tom_
sorry bout the topic description sounds abit :blink: but i have a base ta26 and want a new back wheel i have heard that it wont take more than a 40mm rim so i cant get the echo or try all rim :( is this true. my frame is an 04 and i hear these have a nabbit of cracking is this also true?
cheers (Y)
Sorry dude, yeah they crack after a while. get a block of wood... 50mm wide for good measure and stick it in between your brake pads... if you can set the brake up properly you'll know for sure.
It'll remove the variable of people setting their brake up differently or using different pads etc. ;)
