Tom_ Posted June 17, 2006 Report Share Posted June 17, 2006 hi I brought a pair of new maguras today but the front hose is way to long for my bike. is there any way of trimming it down without having to reebleed the thing.cheers Quote Link to comment Share on other sites More sharing options...
bhups Posted June 17, 2006 Report Share Posted June 17, 2006 Nope Quote Link to comment Share on other sites More sharing options...
Tom_ Posted June 17, 2006 Author Report Share Posted June 17, 2006 will it be cheaper/better to get my local bike shop to do this as i would need to buy the bleed kit and i have never bled a maggy before Quote Link to comment Share on other sites More sharing options...
unicycle boy Posted June 17, 2006 Report Share Posted June 17, 2006 (edited) In the short run it will be, however over time you will save money by buying the kit and practising yourself, I myself did this after going to the bike shop several times where they charged me £15. So I payed £20 for the bleeding kit and have saved around £50 in the last year (I snap my hose quite often) Edited June 17, 2006 by unicycle boy Quote Link to comment Share on other sites More sharing options...
bhups Posted June 17, 2006 Report Share Posted June 17, 2006 I think it will be cheaper, but shouldnt cost to much. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 17, 2006 Report Share Posted June 17, 2006 Just get a syringe from mjcycles with the hosing and stuff and buy a bottle of magura blood, One small bottle will do two /3 bleed's if your completly flushing the system, just topping up it would last for ages, the brakes don't hold much oil really. Quote Link to comment Share on other sites More sharing options...
phil_williams Posted June 17, 2006 Report Share Posted June 17, 2006 or you could just bye a sringe put a nipple in a bit of pipe and wack it on the sringe Quote Link to comment Share on other sites More sharing options...
Tom_ Posted June 17, 2006 Author Report Share Posted June 17, 2006 erm could you explain i think i understand but im not sure. :$ sorry Quote Link to comment Share on other sites More sharing options...
phil_williams Posted June 17, 2006 Report Share Posted June 17, 2006 ]quote name='tom132' date='Jun 17 2006, 10:45 PM' post='977411']erm could you explain i think i understand but im not sure. :$ sorry Quote Link to comment Share on other sites More sharing options...
Joe Aston Posted June 18, 2006 Report Share Posted June 18, 2006 When i first got my 33s i found that the hose was realy long this is because you can use ither break on any side of the bars for weather you like front on right on front on left its up to you.All i did was unscrew the hose from the lever cut the hose put a new niple on (the little brass bit) and scwed it all back to gether dident bother bleeding it and it was fine. You could always bleed with water this is what im running at the moment dosent need a bleeding kit to do it syring would help.Joe Quote Link to comment Share on other sites More sharing options...
BIG L Posted June 18, 2006 Report Share Posted June 18, 2006 Buy a bleeding kit much much cheeper! Quote Link to comment Share on other sites More sharing options...
jamie p Posted June 18, 2006 Report Share Posted June 18, 2006 All i did was unscrew the hose from the lever cut the hose put a new niple on (the little brass bit) and scwed it all back to gether dident bother bleeding it and it was fine. You could always bleed with water this is what im running at the moment dosent need a bleeding kit to do it syring would help.Joethats what i did it works perfect no need to re bleed it again .cheers jamie Quote Link to comment Share on other sites More sharing options...
RatherGood Posted June 18, 2006 Report Share Posted June 18, 2006 Can't you wrap the hose around your handlebars several times Quote Link to comment Share on other sites More sharing options...
Simpson Posted June 18, 2006 Report Share Posted June 18, 2006 shop = £10 - £20 shit job or no job shit bleed e.t.c.D.I.Y. £5 bleed kit which will last forever (in theory)and 99p for a new oliveask one of your riding mates if they can do it for you Quote Link to comment Share on other sites More sharing options...
Tom_ Posted June 18, 2006 Author Report Share Posted June 18, 2006 (edited) evryone who sed that they unscrewed it, cut it and put it back on. did you not end up with lots of air in the system? cheers for the helptom Edited June 18, 2006 by tom132 Quote Link to comment Share on other sites More sharing options...
Joe Aston Posted June 18, 2006 Report Share Posted June 18, 2006 No when i did mine my break was great even with out re bleeding i rebleeded about 3 mounths after couse i snaped a hose. Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 18, 2006 Report Share Posted June 18, 2006 You don't have to bleed the brake if you take that hose off and cut it. Wind the TPA out (so the lever pulls further ), undo the bolt by the cylinder, cut it down, attach new olive at the end, re-attach cable. Simple as that. The fluid won't come out 'cos it'd be creating a vacuum behind it in the hosing if it did move, so you're good to go Just don't flick the hose or whatever, or you may flick some out the end - just be gentle Quote Link to comment Share on other sites More sharing options...
Tom_ Posted June 19, 2006 Author Report Share Posted June 19, 2006 (edited) right i am going to look like an idiot but wich bits the cylinder is it the piston pushed into the lever body when the lever is pulled? :$ cheers Edited June 19, 2006 by tom132 Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted June 20, 2006 Report Share Posted June 20, 2006 bit ov a stupid question you will have to re-bleed it! danny Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted June 20, 2006 Report Share Posted June 20, 2006 bit ov a stupid question you will have to re-bleed it! dannyno bleeding is nessesary when shortening the hose.as a few people have already said! Quote Link to comment Share on other sites More sharing options...
redroy Posted June 20, 2006 Report Share Posted June 20, 2006 Did you get a manual with your brakes?? because it shows you in there how to trim your hoses down without needing to bleed it. Quote Link to comment Share on other sites More sharing options...
basher Posted June 20, 2006 Report Share Posted June 20, 2006 if your going to cut the hose down and do it like onzaboymark said, do it like that then, if you want to bleed it you can bleed it in the bath by undoing the little grub screw next to the lever and the bolt on the cyclinder and then just pumping the lever under water. and replace the bolts under water and its bled. other wise buy a bleed kit from heatsink bikes for £7 and using search learn how to use it. Quote Link to comment Share on other sites More sharing options...
