MikeCottTrials Posted June 17, 2006 Report Share Posted June 17, 2006 ive just tightened it up till i doesnt tighten any more, just wondering if i should really give it some or leave it at that Quote Link to comment Share on other sites More sharing options...
CBProductions Posted June 17, 2006 Report Share Posted June 17, 2006 There should be a leaflet with the bb torque rating on it, if not do a google search for the brand and torque rating. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted June 17, 2006 Report Share Posted June 17, 2006 I'd say give it some, but not extension bar stylee. Mine's not even all the way in....due to some....problems....but its still good, not budged one bit Craig if waynio hits me cos of your sig, ill pass it onto you Quote Link to comment Share on other sites More sharing options...
Mr Dave Posted June 17, 2006 Report Share Posted June 17, 2006 Hope dh ones, are about 32 pounds i thinki ushaly do it a bit more though, dont stay dont upDave Quote Link to comment Share on other sites More sharing options...
IOLO Posted June 17, 2006 Report Share Posted June 17, 2006 get a standard bb tool,twist it till u go, GRRRRRRRRRR !! ahhh !done. Quote Link to comment Share on other sites More sharing options...
chris_g Posted June 17, 2006 Report Share Posted June 17, 2006 ye just tighten it as much as u can dont be using big bars or awt as much as u can do it wi a normal spanner will do christof Quote Link to comment Share on other sites More sharing options...
future orange 660 Posted June 18, 2006 Report Share Posted June 18, 2006 only the right hand side should be very tight. the left hand side without the shoulder shouldnt be as tight as it only provides stability hence they are often plastic.make sure your bb tool is sitting in the bb correctly, if it is slipping you can get a wheel skewer and put that through the axle to hold it in. Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted June 18, 2006 Report Share Posted June 18, 2006 Neither side should be tight to do up if you do it properly Quote Link to comment Share on other sites More sharing options...
Sam Nichols Posted June 18, 2006 Report Share Posted June 18, 2006 Neither side should be tight to do up if you do it properlyUntil you get to the last bit where you need to giver it a bit of welly to make sure she stays tight.As for torque ratings and all that, not everyone has a torque wrench so that's not much use!!I generally tend to find that BB tools and the bit they sit in on the BB itself are proper wank so you can't over tighten it anyway!! Just keep going till you take the skin off your knuckles.. Sorted! Quote Link to comment Share on other sites More sharing options...
