Sam Nugent Posted June 17, 2006 Report Share Posted June 17, 2006 What do I bleed it with? And how do i do it?I have searched but no luck. If someone could post a link to somewhere which would give me these answers that'd be great, if not can someone tell me and say what you use to bleed your mono mini's with.Thanks,Sam Quote Link to comment Share on other sites More sharing options...
quick_spider Posted June 17, 2006 Report Share Posted June 17, 2006 What do I bleed it with? And how do i do it?I have searched but no luck. If someone could post a link to somewhere which would give me these answers that'd be great, if not can someone tell me and say what you use to bleed your mono mini's with.Thanks,SamClick Me!You'll need a bleed kit and some fluid, and some allen keys/spanners Quote Link to comment Share on other sites More sharing options...
Exstionhead Posted June 19, 2006 Report Share Posted June 19, 2006 right u could go a head and buy that kit like but really all u need is some dot 4 or 5.1, a bit of tubing that fits snug onto the bleed nip and a container with some fluid in and a 8mm spanner . Loosen off bleed nipple then put the put the pipe on and put the other end in the tub with the fluid in and open the header tank and top it up as much as possible and as u pull the lever in have the nipple open and then close in before u release it, u will need to keep toping up then header tank as more fluid is pumped though. i normal put 100mel though but do as much as u need. Quote Link to comment Share on other sites More sharing options...
Sam Nugent Posted June 19, 2006 Author Report Share Posted June 19, 2006 Thanks guys, I will have a go sometime Quote Link to comment Share on other sites More sharing options...
