TheChai Posted June 17, 2006 Report Share Posted June 17, 2006 right guys as topic says the tapers on my shitty forge echo cranks are worn, and i need help bodging it onto the bb anyone with quick ideas? i have tried loads of stuff but it still comes loose after 20 mins or so of riding.. anything at all be good Quote Link to comment Share on other sites More sharing options...
King C Posted June 17, 2006 Report Share Posted June 17, 2006 (edited) I think some one mentioned something about some chemical metal once in NMC. Their thread was about bodging rounded square tapers and someone mentioned ISIS tapers and this magical metal stuff.EDIT found it hereOT: I recon chinese people are going to dominate the trials world. Edited June 17, 2006 by kcchan Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted June 17, 2006 Report Share Posted June 17, 2006 Theres always the old coke can and loc tite trick, get a coke can and cut it to fit over the tapers, then degrease the bb taper the can and the crank taper, stick a bit of loc tite on the crank bolt and horse it up TIGHT. Or you could buy new cranks. Quote Link to comment Share on other sites More sharing options...
TheChai Posted June 17, 2006 Author Report Share Posted June 17, 2006 ah that new memebrs thing was good! i used that metal plate they give u for puncture repairsseems fairly solid now if that fails i would try the coke can thanks alot peeps Quote Link to comment Share on other sites More sharing options...
