Gu
MikeCottTrials
There are quite a few square-taper BBs that are well below £30, such as an Onza, VP or something which you can get for around £10-£15 off tartybikes :) . If it's a BB for ISIS drive then for around £30 an FSA Platinum will do the job, check out Chain Reaction Cycles for FSA, Truvativ and many other makes of BB. (Y) As long as you get a 68mm x 128mm BB with the right taper you'll be fine.
