Luzac Posted June 13, 2006 Report Share Posted June 13, 2006 Okey, i've used the search function but it all says diffrent, stone disc, metal disc, 90angle, 45degree angle, clockwise, counter clockwiseso let's solve thisWhat gives the best grind (for ex koxx bloxx)what disc should i use, how fast should i go at the rim and wich angle?i'd appreciate all help i can get since my brake slides real much right nowcheers Quote Link to comment Share on other sites More sharing options...
quick_spider Posted June 13, 2006 Report Share Posted June 13, 2006 I've had good enough results with a stone grinding disc at about a 45 degree angle. My angle grinder only goes one speed. I did the grind and it was good enough when I tested so I didn't muck about any moreMake sure you've got some eye protection first.Jon Quote Link to comment Share on other sites More sharing options...
am4zin Posted June 13, 2006 Report Share Posted June 13, 2006 Earlier on before my exam I was watching all the t33zr bail movies, and I saw he had a video titled 'how to grind' ( http://tv.isg.si/site/filebrowser/teezr )I've never seen it, and my internet is really gay so I can't have a look at it, but hopefully it'll be of some helpDan Quote Link to comment Share on other sites More sharing options...
Luzac Posted June 14, 2006 Author Report Share Posted June 14, 2006 been through a bit of these stuff, , bothers me how my grinds become so dull each time, should i go with a stone cutting or a metal cutting? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 14, 2006 Report Share Posted June 14, 2006 Different people have different results. It really is a case of suck it and see.Grinding disks can be picked up from between 80p and £1.20, so it's not a life changing decision between stone and metal cutting, buy one of each.Peoples grinders all grind at differnet speeds, people hold the rim at different angles, they move the grinders at different speeds down the rim, they go over bits of the rim twice, etc etc.You just have to try it on your rim, and see what you find best. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted June 14, 2006 Report Share Posted June 14, 2006 I have found out iolo's method of disgutingly harsh grinds:Put the wheel in a truing stand or similarset the grinder going and touch on at 0 degrees (parallel)watch the wheel spin at 11,000 rpm or whatever your grinder isThen grind!Mwahahahaa i did this and it came out so beasty! Dont forget goggles!!!!! Quote Link to comment Share on other sites More sharing options...
