Snail Cams
coolbeen
hello
I need to now if my zona zip can run snail cam because my chain tugs are not that good and i have heard lots of good things about snail cam and i don't want to buy some new chain tugs.
Also i want this because they look a lot nicer then chain tug at the back of a bike and i think they work better to then the old chain tugs.
no mate, best of with chain tugs, you will nedd to drill holes in your frame and helicoil them, put bolt through, in order for the snail cams to work, if you do not do this thesnail cams will have nuffin to push against for chain tension and it will be a waste of time!
hope i can help, matt! :-
I suppose you could drill your frame and just put some 4mm bolts in and run them then, i e-mailed tarty about it and they said it will not weakin your frame in anyway. (Y)
Dan.
Daniel your a star :) now...could you tell me if they said that they could do it for you?
I doubt it as it would void the warrenty and if anything did go wrong with the frame it could be them who get held responsible and mithered by whoever's frame it was. So I can't see them doing anything like this really.
Bascially they're like circles with a hole for the axle drilled off-centre and with notches all the way round. As you turn the cam, they pull the wheel back as they work against a bolt which is in the dropout (or a lug if you're posh enough to have a monty frame ;) )
You have 0 chance of getting tarty doing it for you as said above it will void the warranty. to be honest you're better off using chain tugs and i can tell you they work well (Y)
