Tom_ Posted June 13, 2006 Report Share Posted June 13, 2006 i have a base bikes ta26 and cannot get an echo or try all rear rim because they are soooo wide. Would i be alright using a front specific rim or is there differences in strenght etc.cheers for any help tom Quote Link to comment Share on other sites More sharing options...
Fenton Posted June 13, 2006 Report Share Posted June 13, 2006 in my opinion u could but they are weaker and not only that these rims are week enough..so i would suggest not using it for this perpose.. unless u like truing ur wheel every ride and buyin new rims every week. hope ive helped Quote Link to comment Share on other sites More sharing options...
g4ngst4_s4m Posted June 13, 2006 Report Share Posted June 13, 2006 my mate has the same rim on the front and back Quote Link to comment Share on other sites More sharing options...
Jay Jay Posted June 13, 2006 Report Share Posted June 13, 2006 You can get a Mavic D521 rim. Nice and slim but uber strong. Quote Link to comment Share on other sites More sharing options...
planet x alan Posted June 13, 2006 Report Share Posted June 13, 2006 if you ride a TA26 then i guess you ride more street than anything else, the echo rim is designed for natural riding and is made extremely light at the expense of strength. so if you ride street an echo rim is a definate no go. i would definately recommend an onza ronnie for it. very strong rim, mine has stayed true for 4 months and the only problem i got with it was a tiny dent on the side wall and the tiniest flat spot. doesnt affect the riding at all.hope i helped Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted June 13, 2006 Report Share Posted June 13, 2006 viz are awesome too unsure on weather they will fit but they seem very light but also very strong Quote Link to comment Share on other sites More sharing options...
Tom_ Posted June 13, 2006 Author Report Share Posted June 13, 2006 (edited) i do ride nearly all street i was just wondering as i would like to have an anodized blue rim on the rear and i like drilled rims. are ther any drilled rims i could use that come in blue and are less than 40mm widecheers Edited June 13, 2006 by tom132 Quote Link to comment Share on other sites More sharing options...
Tom_ Posted June 13, 2006 Author Report Share Posted June 13, 2006 (edited) and also which hub should i get my rim built up on im thinking of going single speed but im not realy sure Edited June 13, 2006 by tom132 Quote Link to comment Share on other sites More sharing options...
mods Posted June 13, 2006 Report Share Posted June 13, 2006 i doubt that would be a problem, my only concern is that the wholes may be too big, go for it and let us know Quote Link to comment Share on other sites More sharing options...
Danny Foster Posted June 13, 2006 Report Share Posted June 13, 2006 You wouldn't be able to fit a front rim on the back unless, obviously, you had a hub that had the same amount of spokes holes than the rim. But i would just, like some others, advise you to get a Mavic rim. They aren't wide, so they will fit in your frame and they are stupidly strong!! Danny. Quote Link to comment Share on other sites More sharing options...
the judge Posted June 13, 2006 Report Share Posted June 13, 2006 There aren't any drilled rims that come in blue and are less than 40mm wide I'm afraid (unless you get a front one, which I wouldn't like to try as they are not built to take the same ammount of force), so I would say go for an Onza Ronnie. Quote Link to comment Share on other sites More sharing options...
GTF Posted June 15, 2006 Report Share Posted June 15, 2006 the 2005 front echo rim works just fine to use as a rear rim otherwise you can get a onza ronnie rim, they're super good hope this helpscheers Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted June 15, 2006 Report Share Posted June 15, 2006 most front trials rims tend to be singlewall.....so they wont take as much pasty when you land hard-flatspot heaven Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted June 15, 2006 Report Share Posted June 15, 2006 There aren't any drilled rims that come in blue and are less than 40mm wide I'm afraid (unless you get a front one, which I wouldn't like to try as they are not built to take the same ammount of force), so I would say go for an Onza Ronnie. Thought the echo '06's where double constructions on the front too?Mavic and blue paint. Or be a man, Ceramic Quote Link to comment Share on other sites More sharing options...
the judge Posted June 15, 2006 Report Share Posted June 15, 2006 Thought the echo '06's where double constructions on the front too?They are I think, but rear ones are poo to start with so I wouldn't really like to try a front one at the rear. Quote Link to comment Share on other sites More sharing options...
totaltrials Posted June 16, 2006 Report Share Posted June 16, 2006 Using a front echo rim on the rear will be fine, they are double wall still, and even have a higher profile then the rear rims.Phil. Quote Link to comment Share on other sites More sharing options...
